Samsung Smart Home Camera HD Indoor
Quicklinx: BBY4WS00 Mfr#: SNH-E6411BN/EX
  • microSDHC Card
2M (Full HD) helps you to monitor a clearer and brighter video.
Wide angle
The visual angle of 128 degrees can provide wide monitoring coverage for your camera.
Motion zone detection
If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. (max three areas can be set)
Saving in the memory card
You can save your important moments in the memory card*. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere.
* Memory card sold separately.
Easy Installation
It supports the WiFi direct function that allows you to connect your camera to the wireless network.
Real-time alarm
It can detect movements and sounds and sends you real time notifications on your smart phone and PC viewer.
Bi-directional audio
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
Night Vision (5m)
In poorly lit areas, the IR LED is operated automatically to brighten dark images.
Clear colour
IR Cut Filter switches between day and night to provide clearer colour images.
Box Contains
Camera
Quick Guide
Power Adaptor
Network Cable
Screws
Wall Anchors
  • High resolution video
  • Wide angle
  • Motion zone detection
  • Saving in the memory card
    You can save your important moments in the memory card. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere.
  • Easy installation
    It supports the Wi-Fi direct function that allows you to connect your camera to the wireless network.
  • Real-time alarm
  • Bi-directional audio
  • Night vision
  • Clear color
    IR Cut filter switches between day and night to provide clearer color images.
Samsung Techwin SmartCam SNH-E6411BN - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
6.3 cm x 4.16 cm x 9.21 cm
117 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
2 MP
Minimum Illumination
0.3 lux - colour , 0 lux - B&W
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 9 V
Image flip, image mirror, Motion Detection Technology, infrared cut filter, multi-streaming, Audio Detection, Wi-Fi Direct
Environmental Parameters (operating)
0 °C - 40 °C
Audio Support
Wired, wireless
6.3 cm
4.16 cm
9.21 cm
117 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
4
Infrared LEDs
Infrared Distance
5 m
Video Capture
1920 x 1080 @ 30 fps
Image Sensor
2 MP
Network Interface
Network Protocols
SSL
Supported Memory Cards
microSDHC Card
AES
White
Power Requirements
DC 9 V - 1 A
4.8 Watt
