2M (Full HD) helps you to monitor a clearer and brighter video.
Wide angle
The visual angle of 128 degrees can provide wide monitoring coverage for your camera.
Motion zone detection
If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. (max three areas can be set)
Saving in the memory card
You can save your important moments in the memory card*. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere.
* Memory card sold separately.
Easy Installation
It supports the WiFi direct function that allows you to connect your camera to the wireless network.
Real-time alarm
It can detect movements and sounds and sends you real time notifications on your smart phone and PC viewer.
Bi-directional audio
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
Night Vision (5m)
In poorly lit areas, the IR LED is operated automatically to brighten dark images.
Clear colour
IR Cut Filter switches between day and night to provide clearer colour images.
Box Contains
Camera
Quick Guide
Power Adaptor
Network Cable
Screws
Wall Anchors
High resolution video
2M (Full HD) helps you to monitor a clearer and brighter video. -
Wide angle
The visual angle of 128 degrees can provide wide monitoring coverage for your camera. -
If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. -
You can save your important moments in the memory card. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere. -
Easy installation
It supports the Wi-Fi direct function that allows you to connect your camera to the wireless network. -
Real-time alarm
It can detect movements and sounds and sends you real time notifications on your smart phone and PC viewer. -
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam. -
Night vision
In poorly lit areas, the IR LED is operated automatically to brighten dark images. -
Clear color
IR Cut filter switches between day and night to provide clearer color images.
- Samsung Techwin SmartCam SNH-E6411BN - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 6.3 cm x 4.16 cm x 9.21 cm
- 117 g
- White
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- 2 MP
- Minimum Illumination
- 0.3 lux - colour , 0 lux - B&W
- Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 9 V
- Image flip, image mirror, Motion Detection Technology, infrared cut filter, multi-streaming, Audio Detection, Wi-Fi Direct
- Environmental Parameters (operating)
- 0 °C - 40 °C
- Audio Support
- Wired, wireless
- 6.3 cm
- 4.16 cm
- 9.21 cm
- 117 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 4
- Infrared LEDs
- Infrared Distance
- 5 m
- Video Capture
- 1920 x 1080 @ 30 fps
Image Sensor
- 2 MP
- Network Interface
- Network Protocols
- SSL
- Supported Memory Cards
- microSDHC Card
- AES
- White
- Power Requirements
- DC 9 V - 1 A
- Power Device
- 4.8 Watt
- 0 °C
- 40 °C
