Samsung SmartCam HD Pro makes it simpler than ever to keep an eye on home. View your SmartCam through your phone, and set up motion and audio alerts so you don’t miss anything. The SmartCam introduces many advanced features to deliver a high-caliber experience.
Simple Wi-Fi Setup
Simply download the free Samsung SmartCam app for Android or iOS, available on the App Store® and Google Play®, to your mobile device and the intuitive set up wizard helps you begin viewing your camera in a matter of minutes.
1080p Full HD Video
The SmartCam HD Pro Wi-Fi® camera provides up to 1080p Full HD streaming video to your mobile device, while the large 1/2.8-inch CMOS sensor allows maximum light, yielding vivid colors, brighter video and stunning detail.
Two-Way Talk
Enhanced Two-Way Talk feature not only lets you hear what’s going on around the camera but also allows you to talk back through your phone, no matter where you are. You can also enhance the sound quality with external speakers.
Advanced Detection
Advanced motion and audio detection knows the difference between a rustling plant and true motion. If your pet enters an "off-limits" room, the kids come home from school or a window is shattered, you’ll immediately be notified.
Motion Zone Select
You can select up to three motion zones in the camera’s field of view by simply drawing a box around them on your screen. The camera will alert you when there are qualifying movements in the zone.
Local Video Storage
A microSD™ card slot on the SmartCam lets you locally store up to 64GB on a microSDXC memory card. Set your camera for continuous recording, record at scheduled times or set up motion and sound detection.
Push Notifications
Know what’s going on, even when you’re away, with instant push notifications or emails sent directly to your mobile device when your camera detects motion or sound.
Ultra-Wide Angle
While other cameras have constricted angles that limit your view, Samsung’s 128° ultra-wide angle lens gives you a wider view to maximize your recording coverage without compromising quality.
True Day and Night
The SmartCam HD Pro features an advanced IR cut filter for accurate, vibrant colors. Even in darkness, the camera provides clear, night-time video up to 16 feet.
Light Enhancer
The Samsung Light Enhancer enriches available light in dark areas to give you superior image detail even in the most challenging low-light conditions.
Wide Dynamic Range
The WDR technology enhances details in backlit conditions to give you a clear view of the outside while eliminating murky silhouettes in the foreground.
- Samsung Techwin SmartCam - network surveillance camera
- Network surveillance camera
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Optical Sensor Type
- CMOS
- Ethernet 10Base-T/100Base-TX, IEEE 802.11n
- Wired, wireless
Camera
- Digital Video Format
- MJPEG, H.264
Image Sensor
- CMOS
- Network Interface
