2M (Full HD) helps you to monitor a clearer and brighter video. Because it is compact and slim, it is easy to install anywhere in your home while saving some space. The device supports the Wi-Fi Direct function that allows you to connect your camera to the wireless network.
High resolution video
2M (Full HD) helps you to monitor a clearer and brighter video. -
Compact and slim design
Because it is compact and slim, it is easy to install anywhere in your home while saving some space. -
Motion zone detection
If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. -
Easy installation
It supports the Wi-Fi Direct function that allows you to connect your camera to the wireless network. -
Real-time alarm
It can detect movements and sounds and sends you real time notifications on your smart phone and PC viewer. -
Bidirectional audio
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
- Samsung Techwin SmartCam SNH-V6110BN - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 5.1 cm x 1.95 cm x 9.32 cm
- 85 g
- White
- Connectivity Technology
- Wireless
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080/30p
- Optical Sensor Type
- 2 MP
- Minimum Illumination
- 15 lux - colour
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Motion Detection Technology, Audio Detection, Wi-Fi Direct
- Environmental Parameters (operating)
- 0 °C - 40 °C; 0 - 90% relative humidity
- Audio Support
- Wireless
- 5.1 cm
- 1.95 cm
- 9.32 cm
- 85 g
Camera
- Colour - fixed
- Digital Video Format
- MJPEG, H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080/30p
- Digital Zoom
- 4
- 15 lux - colour
- Digital Video Capture Resolution
- 1280 x 720, 1920 x 1080, 640 x 360
- Frame Rate (max)
Image Sensor
- 2 MP
- Network Interface
- Network Protocols
- SSL
- AES-256
- White
- Power Requirements
- DC 5 V - 1 A
- Power Device
- 5 Watt
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 90%
