Product
Samsung Smart Home Cam HD Indoor Mini
Quicklinx: CYKHWS00 Mfr#: SNH-V6110BN/EX
2M (Full HD) helps you to monitor a clearer and brighter video. Because it is compact and slim, it is easy to install anywhere in your home while saving some space. The device supports the Wi-Fi Direct function that allows you to connect your camera to the wireless network.
  • High resolution video
  • Compact and slim design
  • Motion zone detection
    If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area.
  • Easy installation
    It supports the Wi-Fi Direct function that allows you to connect your camera to the wireless network.
  • Real-time alarm
    It can detect movements and sounds and sends you real time notifications on your smart phone and PC viewer.
  • Bidirectional audio
    Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
Samsung Techwin SmartCam SNH-V6110BN - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5.1 cm x 1.95 cm x 9.32 cm
85 g
White
Wireless
Camera
Max Resolution
1920 x 1080
Frame Rate
30 frames per second
Motion Detection
Video Modes
1080/30p
Optical Sensor Type
2 MP
Minimum Illumination
15 lux - colour
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Motion Detection Technology, Audio Detection, Wi-Fi Direct
Environmental Parameters (operating)
0 °C - 40 °C; 0 - 90% relative humidity
Audio Support
Wireless
5.1 cm
1.95 cm
9.32 cm
85 g
Camera
Colour - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080/30p
Digital Zoom
4
15 lux - colour
Digital Video Capture Resolution
1280 x 720, 1920 x 1080, 640 x 360
Frame Rate
Image Sensor
2 MP
Network Interface
Network Protocols
SSL
AES-256
White
Power Requirements
DC 5 V - 1 A
5 Watt
Relative Humidity (operating)
0 - 90%
