Samsung SM863a 480GB 2.5 Enterprise SATA Class SSD
Quicklinx: D7MKWS00 Mfr#: MZ7KM480HMHQ-00005
With a higher level of endurance, the SATA 2.5" SM863a SSD is the ideal choice for write-intensive applications such as servers for OLTP, email and database.
  • Sustain endurance with V-NAND technology
    The SM863 is designed with Samsung V-NAND technology to provide all the essentials for data center environments - more capacity, speed, endurance and power efficiency.
  • Accelerate performance
    The SM863a delivers outstanding random read/write IOPS. It also boasts exceptionally low latency and a high level of QoS, imperative for fast processing servers.
  • Increase data security
    The SM863a protects data with AES 256-bit hardware-based encryption. This encryption engine secures data without the performance degradation often experienced with software-based encryption.
  • Ensure data integrity
    The SM863a demonstrates a low probability of data corruption. End-to-end protection keeps data consistent along the entire data transfer path.
Samsung SM863a MZ7KM480HMHQ - SSD - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
2.5"
SATA 6Gb/s
Buffer Size
512 MB
TRIM support, End-to-end data protection, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Worldwide Name (WWN), Enterprise, 24x7 availability, Low Power DDR3 SDRAM Cache, Advanced ECC Engine, Mercury controller, V-NAND Technology, power loss data protection, S.M.A.R.T., 256-bit AES
69.85 mm x 100.2 mm x 6.8 mm
54.3 g
5-year warranty
480 GB
2.5"
SATA 6Gb/s
Buffer Size
512 MB
69.85 mm
100.2 mm
6.8 mm
54.3 g
Performance
Drive Writes Per Day (DWPD)
3.6
Internal Data Rate
510 MBps (read) / 485 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
19000 IOPS
Reliability
MTBF
2,000,000 hours
24x7 Operation
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
2.8 Watt (write) , 2.3 Watt (read) , 1.3 Watt (idle)
Limited warranty - 5 years
70 °C
