Product
Brand
Samsung SL46B 46" 1920x1080 VGA DVI HDMI DP VESA 1500CD LED LFD
Quicklinx: 9HNJWS00 Mfr#: LH46SLBPLBC/EN
  • 1080p (Full HD)
SL46B is a super-high brightness indoor display solution, the Samsung SL46B is ideal for high ambient light conditions such as retail storefront windows. A slim 12mm bezel allows for diversified stand alone or video wall solutions giving retailers the option to tile multiple displays in a storefront window environment.
Samsung SL46B 46" LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Video Wall Components Qty
100
Video Interface
Component, composite, HDMI
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
S-PVA
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
2 speakers
Remote Control
Standard remote
Voltage
356 Watt
104.94 cm x 12.5 cm x 60.26 cm
26.8 kg
356 Watt
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
Sensors
Temperature sensor
Video Interface
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
100
Dimensions
Without stand
104.94 cm
12.5 cm
60.26 cm
26.8 kg
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Colour Depth
16.7 million colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
10000:1
Brightness
1500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
8 ms
Pivot, Multiple Display Control (MDC), Lamp Error Detection, anti-image retention, MagicInfo Lite
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Standard remote
Audio System
Sound Output Mode
Stereo
Speaker System
2 speakers
Speakers
2 x main channel speaker - built-in
Connector Type
HDMI , Composite video/audio input , Audio line-in , DVI-D input , VGA input , Audio line-out , Serial input , Serial output , DVI-D output
VGA cable
Plug and Play, EN55022, EN55024
Power supply
Nominal Voltage
Power Consumption Stand by / Sleep
1 Watt
1 Watt
Width (Shipping)
114.5 cm
Depth (Shipping)
30 cm
Height (Shipping)
72.6 cm
Weight (Shipping)
32.6 kg
30 °C
10 - 80%
