Your basket is empty
Samsung SDH-B3040 DVR + Camera(s)
Quicklinx: BBYDWS00 Mfr#: SDH-B3040
The 4-channel Analog High Definition (AHD) Security System includes 4 IP-66 rated weather-resistant cameras delivering 720p resolution at the fraction. It offers true daylight and clear night vision up to 82ft. The system is simple to install and easy to use as the traditional analog CCTV systems.
SAMSUNG TECHWIN SDH-B3040 - DVR + camera(s)
System
DVR + camera(s)
Security DVR
4 channels
Hard Drive
1 x 1 TB
Camera
4 cameras - outdoor - NTSC/PAL - night vision
30 cm x 20.87 cm x 4.8 cm
1.44 kg
System
DVR + camera(s)
Package Content
4 cameras, DVR, remote control, mouse, power adapter, 2 AAA batteries
Camera cable - 18.3 m - 1 pcs. , HDMI cable - 2 m - 1 pcs. , Network cable - 1 pcs.
Software Included (Y)
Drivers & Utilities
Security DVR
Video Channels
4
Frame Rate (Playback)
120 fps
Frame Rate (Record)
100 fps
Image Resolution
1280x720, 704x576, 960x576 (PAL)
Compression Format
MJPEG, G.711, H.264
Record Events
Motion detection, scheduled, event, manual, continuous, tamper detection, time lapse, video loss
Watermark, SmartViewer, Webviewer, smartphone support, Mobile Viewer, 3-Dimensional noise reduction
Hard Drive
Quantity Installed
1
1 TB
Cameras
Quantity
4 cameras
Camera Type
Outdoor
Sensor
CMOS - 1/3" - 1280x960
Field Of View
78° (H), 62.5° (V)
TV System
NTSC/PAL
Sensitivity (lux)
0
Night Vision
Infrared LEDs
Infrared Distance
25 m
White Balance
Auto
Gain Control
Auto
Focal Length
3.6 mm
Voltage
DC 12 V
Power Consumption
4 Watt
-10 °C
50 °C
Operating Humidity
0-90%
IP66
Video Input Ports
BNC x 4
Video Output Ports
HDMI x 1, VGA x 1
Audio Input Ports
RCA x 4
Audio Output Ports
RCA x 1
Network Port
10/100Base-T
Other Ports
USB 2.0 x 2, eSATA x 1, serial RS-485 x 1
30 cm
20.87 cm
4.8 cm
1.44 kg
Details
DVR: 30 cm x 20.87 cm x 4.8 cm - 1.44 kg , Camera: 6.18 cm x 14 cm x 6.18 cm - 194 g
