Wireless charging convenience
Say goodbye to tangled wires and lost charging cables. The Samsung wireless charging convertible utilizes Qi inductive charging technology, that eliminates the need to fumble with charging cables each time you want to charge your device. Perfect for at home or the office, the dedicated wireless charger is always at the ready, providing wireless power whenever you set your device on it. The stand was designed to allow you to still use your device while charging, propping it up, so you can navigate music, review notifications and answer calls without having to interrupt charging. -
Easy to use
The Samsung wireless charging convertible is easy to set up and use. First, connect the wireless charger to your device's charging cable and then place your phone on the stand. For optimal performance, your device should be placed in the center of the pad. The built-in LED indicator light will alert you, if the device is not properly aligned and when a good charge alignment is acquired.
- Samsung Fast Charge Wireless Charging Convertible EP-PG950 wireless charging stand
- Product Type
- Wireless charging stand
- 2.86 cm
- Diameter
- 11.74 cm
- 227 g
- Black
- Voltage Required
- 5 - 9 V
- Voltage Provided
- 5 - 9 V
- Max Electric Current
- 2 A
- Wireless Charging Standards
- WPC, Qi
- Designed For
- Galaxy S8, S8+
- Product Type
- Designed For
- Mobile phone
- 2.86 cm
- Diameter
- 11.74 cm
- 227 g
- Enclosure Colour
- Black
- Voltage Required
- 5 - 9 V
- Input Connectors
- 24 pin USB-C
- Voltage Provided
- 5 - 9 V
- 2 A
- WPC, Qi
- Designed For
- Samsung Galaxy S8, S8+
