The Samsung LED wallet cover is a multifunctional case, that stores cards in the interior pocket and shows you LED notifications on the outside. On the front cover LED lights will notify you of incoming calls, messages, current time, and more. Simply press the phone's power button with a closed case to get all your information. Answer or reject calls by swiping the cover. View/receive LED notifications directly on the cover.
- Samsung LED View Cover EF-NG955 - flip cover for mobile phone
- Product Type
- Flip cover for mobile phone
- 7.64 cm x 1.36 cm x 16.09 cm
- 71.1 g
- Violet
- Designed For
- Galaxy S8+
- 7.64 cm
- 1.36 cm
- 16.09 cm
- 71.1 g
- Violet
Carrying Case
- Protective cover
- Recommended Use
- For mobile phone
- Cover Type
- Flip cover
- Open Type
- Side
- Additional Compartments
- Credit cards
- Cover Features
- Notification LED
- Designed For
- Samsung Galaxy S8+
