The big, brilliant screen flows over, bringing life to everything you see. Knowing how important music is to you, the sound quality, video capabilities were given a boost. Your videos will be impressive enough to share with the world. You can’t risk running out of power when there’s so much to say, watch and do. This smartphone has the long battery life you need and fast charging power, uninterrupted, even without a cable. The great mobile camera was improved, because taking photos is a way of life. Whether it’s a big event or coffee with friends, you will be able to capture it all in great light. It's great to see the incredible photos and videos you took on the camera up on a large screen. Connect your phone to your TV via Bluetooth with just one tap.
A reimagined design, inside and out
This smartphone is powerful to use and beautiful to behold. The slim and lightweight, all-metal body and curved glass design make a bold statement, while the lightning-fast processor delivers amazing power and speed. -
Amazing experience
The dual-edge screen and Quad HD display create a distinctive look and feel for all to see. It creates a more immersive experience with things like shortcuts to your five favorite people, and when your favorite contacts call or text, its dual-edge screen lights up in bold, distinctive colors. -
Stunning display
Despite its ability to fit in your palm this device has the amazing imagination of HDTVs. The Quad HD Super AMOLED display shows everything brighter, clearer and more captivating on screen, and even automatically adjusts to all light conditions. -
Perfect smartphone camera
This smartphone powers your selfies with a cool front-facing camera and a wide-angle lens, allowing you to capture more of the background and all of your friends. And if you double tap the home key, it will quickly launch from any screen. The ultra-responsive rear-facing camera with built-in Optical Image Stabilization and Auto HDR will help you to take great shots anywhere, anytime. -
Fast charging and power saving
Equipped with fast-charging battery, exclusive Ultra Power Saving mode and built-in wireless charging capabilities, this smartphone keeps you connected to all the things you love. With fast charging, your battery is half-charged in less than an hour. And in Ultra Power Saving mode with low power, you’ll still get calls and texts.
- Samsung Galaxy S6 edge+ - black sapphire - 4G smartphone - 64 GB - GSM
- Product Type
- 4G smartphone
- Manufacturer Model Number
- SM-G928F
- Display
- OLED display - 2560 x 1440 pixels - 5.7" - 518 ppi - Quad HD Super AMOLED - Corning Gorilla Glass 4 (scratch resistant glass)
- Heart rate sensor
- Processor
- Exynos 7 Octa 7420 (8-core) - 64-bit
- Memory
- RAM 4 GB / 64 GB
- Operating System
- Android 5.1 (Lollipop)
- Main Camera
- 16 Megapixel - f/1.9 - focus: automatic
- Front Camera
- 5 Megapixel - wide-angle lens - f/1.9
- Service Provider
- Not specified
- SIM Card
- Nano SIM
- Wireless Interface
- Infrared, NFC, Wi-Fi 5, Bluetooth, ANT+/ANT
- Security Devices
- Fingerprint reader
- Messaging Services
- Facebook Messenger, Google+ Hangouts, SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Black sapphire
- 75.8 mm x 6.9 mm x 154.4 mm
- 153 g
- Specific Absorption Rate (SAR)
- 0.216 W/kg (head) , 0.58 W/kg (body)
- Product Type
- Smartphone
- SM-G928F
- Form Factor
- Touch
- Integrated Components
- Heart rate sensor
- 75.8 mm
- 6.9 mm
- 154.4 mm
- 153 g
- Body Colour
- Black sapphire
- SAR Value
- 0.58 W/kg (body), 0.216 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Navigation
- A-GPS, GLONASS
- SIM Card Type
- Nano SIM
- Input Device
- Multi-touch, capacitive
Messaging & Internet
- Supported Email Protocols
- POP3, IMAP4
- Supported Social Networks and Blogs
- Facebook, Google+
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- Infrared (IrDA), NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT
- Bluetooth Profiles
- HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, PBAP, MAP, DIP, HOGP
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, gyro sensor, hall sensor, heart rate, geomagnetic sensor
- Security Devices
- Additional Features
- TTY compatible, software updates FOTA (Firmware Over The Air), infrared remote control, MIMO technology, Ultra Power Saving Mode, notification LED, Google Voice typing function, 64-bit architecture, Dual Curved display, Noise suppression by Audience
Media Player
- Supported Digital Audio Standards
- WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, AWB, IMY, RTTTL, RTX, OTA, MP4
- Supported Digital Video Standards
- MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2
- Exynos 7 Octa
- Processor Number
- 7420
- Processor Core Qty
- 8-core
- 64-bit Architecture
- RAM
- 4 GB
- Internal Memory Capacity
- 64 GB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/1.9
Main Camera
- Sensor Resolution
- 16 Megapixel
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.9
- Focus Adjustment
- Automatic
- Digital Zoom
- 8x
- Special Effects
- Collage
- Camera Modes
- Pro mode, wide selfie mode, Fast Motion mode, Virtual Shot
- HDR Mode
- Auto HDR mode
- White Balance
- Automatic
- Light Source
- LED light
- Video Resolutions
- 3840 x 2160 (4K)
- Selective Focus, Quick Launch, Smart OIS, Tracking Focus
Display
- OLED display
- Technology
- Diagonal Size
- 5.7"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 518 ppi
- Colour Depth
- 16.7 million colours
- Protection
- Connector Type
- Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm
- Technology
- Lithium Ion
- Capacity
- 3000 mAh
- HAC (Hearing Aid Compatible)
- Included Accessories
- Power adapter
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
