Samsung S34J550WQU 34.1" 3440x1440 4ms HDMI LED Monitor
Quicklinx: F5JQWS00 Mfr#: LS34J550WQUXEN
With its ultra-wide screen and high resolution, the SJ55W provides all the workspace you need to comfortably multitask on a single screen. And whether you're working on documents, playing games, or watching movies, you'll enjoy all your content in superbly detailed quality.
  • Superior image quality
    With an incredible screen resolution, the SJ55W delivers razor-sharp images. And with extra pixels to display content, you can view more web pages and documents at the same time without scrolling or zooming out.
  • Stylish and practical
    The SJ55W's slim panel, elegant stand, and metallic bezel bring quality and style to the workplace or home.
  • Smoother gameplay
    The monitor synchronizes the refresh rate of your graphics card and monitor to reduce image tear and stutter.
Samsung S34J550WQU - SJ55W Series - LED monitor - 34.1"
LED-backlit LCD monitor - 34.1"
Energy Class
Class G
Energy Consumption per Year
51 kWh
Power Consumption (On mode)
35 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Dark grey/blue
82.81 cm x 24.28 cm x 47.08 cm
6.9 kg
DisplayPort 1.2
Display Type
Energy Class
Class G
51 kWh
Diagonal Size
34.1"
Viewable Size
34"
AMD FreeSync
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, picture by picture, game mode, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Low Input Lag, Picture-in-Picture
Dark grey/blue
82.81 cm x 24.28 cm x 47.08 cm - with stand
6.9 kg
DisplayPort , Headphones , 2 x HDMI
Mechanical
Tilt
Tilt Angle
-1.5/15
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
DisplayPort 1.2
Input Voltage
AC 120/230 V
35 W
35 kWh/1000h
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 82.81 cm - depth: 24.28 cm - height: 47.08 cm - weight: 6.9 kg , Without stand - width: 82.81 cm - depth: 10.57 cm - height: 36.94 cm - weight: 6.4 kg
Shipping Width
89.7 cm
Shipping Depth
43.9 cm
Shipping Height
16.5 cm
Shipping Weight
9.5 kg
10 °C
10 - 80% (non-condensing)
