A natural fit for your eyes with a curvature of 3,000 R, delivering a wider field of view that's easy on the eyes for a more comfortable viewing experience. Experts have found that people perceive curves as more visually comforting than hard lines and angles. Simply viewing the curves of an object triggers relief in the brain.
More vivid than conventional monitors to provide truly brilliant pictures with deeper blacks, pristine whites, amazingly bright colors, and less light leakage.
More vivid and brilliantly clear with the highest brightness level of 350 cd/sq m enables you to see every intricate detail. Wide viewing angle: delivers a 178° wide viewing angle horizontally and vertically for optimal viewing experience from any angle.
With thoughtful design and engineering, the SE590C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it's carefully designed to keep the focus on your content viewing pleasure.
3,000 R curvature
A natural fit for your eyes with a curvature of 3,000 R, delivering a wider field of view that's easy on the eyes for a more comfortable viewing experience. Experts have found that people perceive curves as more visually comforting than hard lines and angles. Simply viewing the curves of an object triggers relief in the brain. -
5,000:1 static contrast ratio
More vivid than conventional monitors to provide truly brilliant pictures with deeper blacks, pristine whites, amazingly bright colors, and less light leakage. -
High brightness level
More vivid and brilliantly clear with the highest brightness level of 350 cd/sq m enables you to see every intricate detail. Wide viewing angle: delivers a 178° wide viewing angle horizontally and vertically for optimal viewing experience from any angle. -
Built-in dual stereo speakers
The SE590C was created with 5-Watt, 2-channel dual stereo speakers built right into the curve. Thanks to Samsung's proprietary Dual Sound Engine and acoustic mechanical engineering technology, the speakers deliver original sound that is richer than speakers with a single engine. -
Game Mode
Instantly adjust your monitor settings for an optimized gaming experience through the on-screen display. Game Mode improves the darkness of the picture so that you can see all the action vividly. -
Fast 4 ms response time/60 Hz refresh rate
See even the fastest on-screen motion clearly and smoothly without any motion blur, judder or ghosting. Take your entertainment to new heights of immersion and comfort -
Eye Saver Mode
Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. -
Flicker Free
Flicker Free technology reduces screen flickering for a more comfortable viewing experience. -
Sophisticated design
With thoughtful design and engineering, the SE590C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it's carefully designed to keep the focus on your content viewing pleasure. -
VESA Support
With support for VESA 200 x 200, you can easily mount it on any wall.
- Samsung S32E590C - SE590C Series - LED monitor - curved - Full HD (1080p) - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class B
- Energy Consumption per Year
- 66 kWh
- Power Consumption (On mode)
- 45 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.36375 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 5000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DisplayPort
- Speakers
- Internal
- Tilt
- Voltage
- AC 120/230 V
- Black
- 72.91 cm x 21.43 cm x 52.39 cm
- 6.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class B
- 66 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.36375 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 5000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
- Black
- 72.91 cm x 21.43 cm x 52.39 cm - with stand
- 6.9 kg
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 5 Watt
- DisplayPort , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- 15
- VESA Mounting Interface
- 200 x 200 mm
- Cables Included
- 1 x HDMI cable
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- 45 W
- Power Consumption (Typical)
- 34 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 72.91 cm - depth: 21.43 cm - height: 52.39 cm - weight: 6.9 kg , Without stand - width: 72.91 cm - depth: 9.06 cm - height: 42.51 cm - weight: 6 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
