Samsung S32E590C 31.5" 1920x1080 4ms HDMI DisplayPort Curved LED Monitor
Quicklinx: B8LHWS00 Mfr#: LS32E590CS/EN
A natural fit for your eyes with a curvature of 3,000 R, delivering a wider field of view that's easy on the eyes for a more comfortable viewing experience. Experts have found that people perceive curves as more visually comforting than hard lines and angles. Simply viewing the curves of an object triggers relief in the brain.
More vivid than conventional monitors to provide truly brilliant pictures with deeper blacks, pristine whites, amazingly bright colors, and less light leakage.
More vivid and brilliantly clear with the highest brightness level of 350 cd/sq m enables you to see every intricate detail. Wide viewing angle: delivers a 178° wide viewing angle horizontally and vertically for optimal viewing experience from any angle.
With thoughtful design and engineering, the SE590C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand with a metallic touch, it's carefully designed to keep the focus on your content viewing pleasure.
  • 3,000 R curvature
  • 5,000:1 static contrast ratio
  • High brightness level
  • Built-in dual stereo speakers
    The SE590C was created with 5-Watt, 2-channel dual stereo speakers built right into the curve. Thanks to Samsung's proprietary Dual Sound Engine and acoustic mechanical engineering technology, the speakers deliver original sound that is richer than speakers with a single engine.
  • Game Mode
    Instantly adjust your monitor settings for an optimized gaming experience through the on-screen display. Game Mode improves the darkness of the picture so that you can see all the action vividly.
  • Fast 4 ms response time/60 Hz refresh rate
    See even the fastest on-screen motion clearly and smoothly without any motion blur, judder or ghosting. Take your entertainment to new heights of immersion and comfort
  • Eye Saver Mode
    Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free
    Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
  • Sophisticated design
  • VESA Support
    With support for VESA 200 x 200, you can easily mount it on any wall.
Samsung S32E590C - SE590C Series - LED monitor - curved - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36375 mm
Brightness
350 cd/m²
Contrast Ratio
5000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Speakers
Internal
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
72.91 cm x 21.43 cm x 52.39 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
66 kWh
Diagonal Size
32"
Viewable Size
31.5"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36375 mm
Brightness
350 cd/m²
Contrast Ratio
5000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
72.91 cm x 21.43 cm x 52.39 cm - with stand
6.9 kg
Audio
Speakers - stereo - internal
Output Power / Channel
5 Watt
DisplayPort , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
15
VESA Mounting Interface
200 x 200 mm
1 x HDMI cable
Power Supply
External
Input Voltage
AC 120/230 V
45 W
Power Consumption (Typical)
34 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 72.91 cm - depth: 21.43 cm - height: 52.39 cm - weight: 6.9 kg , Without stand - width: 72.91 cm - depth: 9.06 cm - height: 42.51 cm - weight: 6 kg
Sustainability Information
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
