Samsung S32D850T 32" 2560 x 1440 5ms HDMI LED Monitor
Quicklinx: BWXMWS00 Mfr#: LS32D85KTSR/EN
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, DVI, HDMI
39 in stock
£332.63 ex VAT
£399.15 inc VAT
The SD850 has 2560 x 1440 wide quad high-definition (WQHD) resolution, twice that of Full HD, with a 178° viewing angle. The monitor can display over one billion colors, incorporating 100 per cent of the sRGB color space. Its approximate 3.7 million pixels offer deep and rich image detail for a more realistic picture. Aimed at content creaters, programmers and those in financial services, the monitor can not only display picture-in-picture in 720p, but also picture-by-picture to display images from two separate sources, such as a laptop and a desktop PC.
The SD850 has an eco light sensor that adapts the brightness of the monitor dynamically according to available light to save power. The monitor also has an Energy Star rating of 6.0 to ensure efficiency. The materials that make up the SD850 have also been TCO Certified.
  • Business monitor
    The panel provides more screen real estate, while high resolution provides more pixels, along with wide viewing angles. So you can enjoy greater viewing clarity, be more productive and maximize efficiency.
  • Seamless multi-screen functionality
    With split screen, you can connect two separate sources to the display and view them simultaneously.
Samsung S32D850T - SD850 Series - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
82 kWh
Power Consumption (On mode)
56 W
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.27675 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Titanium silver, matte black
74.13 cm x 28 cm x 50 cm
12.2 kg
Environmental Standards
TCO Certified
UL, TUV, VCCI, C-Tick, EN55022, EN55024, CB, CCC, PSB, AS/NZS 3548, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24
3-year warranty
Display Type
Energy Class
Class B
82 kWh
56 W
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.27675 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
1 billion colours
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, power off timer, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Eco Saving, Magic Upscale, auto-rotation, Mercury free, Image Size
74.13 cm x 28 cm x 50 cm - with stand
12.2 kg
DVI , DisplayPort , HDMI , Audio line-in , Headphones , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
1 x HDMI cable , 1 x DVI cable , 1 x USB cable , 1 x DisplayPort cable , 1 x Mini DisplayPort-DisplayPort adapter
Power Supply
Internal
46 Watt
Power Consumption Stand by
0.45 Watt
Dimensions & Weight Details
With stand - width: 74.13 cm - depth: 28 cm - height: 50 cm - weight: 12.2 kg , Without stand - width: 74.13 cm - depth: 6.85 cm - height: 44.1 cm - weight: 9.4 kg
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Samsung S32D850T 32 Bundle deal on Samsung S32D850T 32" 2560 x 1440 5ms HDMI LED Monitor
£431.80
Diagonal Size: 32in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: 300 - 500
