Your basket is empty
Samsung S32D850D 32" 2560x1440 5ms DVI HDMI DisplayPort USB LED Monitor
Quicklinx: B4RLWS00 Mfr#: LS32D85KTSN/XU
The ergonomics of the SD850 helps make your professional work space convenient and comfortable. Samsung's height adjustable stand (HAS) design lets you adjust the monitor height by up to 130mm. You can pivot, swivel, and tilt to adjust the perspective from horizontal to vertical. It even supports Auto OSD Rotation so you don't have to change the aspect ratios when you want to pivot your screen.
The SD850 features a bezel that helps provide a deeply immersive viewing experience that lets you concentrate on the tasks at hand.
View from various angles with the SD850. The Samsung LED Monitor has a wide viewing angle, vertically and horizontally.
With Picture-by-Picture (PBP), you can connect two compatible PCs to the same monitor and see the desktops of both simultaneously on one screen that's divided into two. Thanks to PBP and the WQHD resolution size you won't have to worry about losing the picture quality and resolution. Plug in your compatible laptop and your desktop and use both without needing to keep looking between different monitors - it's all there at a glance.
Samsung's latest Picture-in-Picture 2.0 technology lets you multi-task and watch videos. Whether it's 720p or 480p, PIP 2.0 doesn't downscale contents and helps maintain the same resolution as clear and crisp on its own. It supports resolutions up to HD and you can adjust the PIP resolution and position to help fit your needs.
The SD850's light sensor adjusts the screen brightness to help match your environment so that the screen is visible in a range of lighting conditions.
Samsung 8 Series S32D850T - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.27675 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
Titanium silver, matte black
74.13 cm x 28 cm x 50 cm
12.2 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV, C-Tick, EN55022, EN55024, CCC, PSB, AS/NZS 3548, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, GB 4943-2001 PSB, GB 17625.1-2003 EMC, KN22, KN24, K60950-1, IEC60950-1
3 years warranty
Display Type
Energy Class
Class B
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
MVA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.27675 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Eco Saving, Magic Upscale, auto-rotation, Mercury free, Image Size, PIP 2.0, PBP, USB Super-charging
74.13 cm x 28 cm x 50 cm - with stand
12.2 kg
DVI-D (dual link) , HDMI , Headphones , DisplayPort , Audio line-in , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x DVI cable , 1 x USB cable
Power Supply
Internal
46 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 74.13 cm - depth: 28 cm - height: 50 cm - weight: 12.2 kg , Without stand - width: 74.13 cm - depth: 6.85 cm - height: 44.1 cm - weight: 9.4 kg
ENERGY STAR Certified
Limited warranty - 3 years
B4RL C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B4RL C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
B4RL C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
B4RL C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
B4RL C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
B4RL C2G Pro HDMI to VGA Converter In Stock £46.35
