Samsung S27R750Q 27" 4K UHD Space Monitor
Quicklinx: F5JNWS00 Mfr#: LS27R750QEUXEN
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: None
Interfaces: HDMI, Mini DisplayPort
39 in stock
£290.88 ex VAT
£349.05 inc VAT
The Samsung SR75 Series is designed to let you reclaim your work space. Occupying a minimum of desk space and leaving work areas clear when not in use, the Samsung monitor is the ideal solution wherever space is at a premium.
  • Space-saving design
    When not in use, the Samsung monitor pushes back to sit flat against a back wall to leave your entire work surface clear. When it's time for use, simply pull the Samsung monitor towards you and adjust to your preferred viewing position.
  • Concealed cables
    The Samsung monitor arm stand neatly conceals its power/HDMI cable in recessed channels to prevent tangling and keep your work space clear and free from clutter.
  • Stylish design
    With its slim panel featuring a 3-sided bezel-less screen, the Samsung monitor offers an understated stylish solution for any workplace or home interior.
  • Height-adjustable arm stand
    The Samsung monitor's zero-level height adjustable arm stand allows easy positioning of the screen for optimal comfort and convenience.
  • Adjustable eye level
    The Samsung monitor can be quickly and easily raised or lowered to the optimal viewing height of any user, making it a versatile solution for use at home or in public spaces such as libraries.
Samsung S27R750Q - SR75 Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
70 kWh
Power Consumption (On mode)
48 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 144 Hz
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Input Connectors
Display Position Adjustments
Height, tilt
61.48 cm x 11.55 cm x 73.03 cm
5.8 kg
Display Type
Energy Class
Class C
70 kWh
48 W
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
1 billion colours
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, frameless, game mode, Mega Dynamic Contrast Ratio, 100% sRGB colour gamut, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, 72% (NTSC 1976) colour gamut, Picture-in-Picture, Picture-by-Picture
61.48 cm x 11.55 cm x 73.03 cm - with stand
5.8 kg
HDMI , Mini DisplayPort
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
213.9 mm
Dual Hinge stand
HDMI cable
48 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 61.48 cm - depth: 11.55 cm - height: 73.03 cm - weight: 5.8 kg , Without stand - width: 61.48 cm - depth: 2.6 cm - height: 36.21 cm - weight: 3.6 kg
Shipping Width
88.1 cm
Shipping Depth
15.9 cm
Shipping Height
44.8 cm
Shipping Weight
7.8 kg
Limited warranty - 2 years - carry-in
10 °C
10 - 80% (non-condensing)
Samsung S27R750Q 27 Bundle deal on Samsung S27R750Q 27" 4K UHD Space Monitor
£390.05
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Samsung
Price Range Ex VAT: 150 - 300
