Samsung S27R750Q 27" 4K UHD Space Monitor
Quicklinx: F5JNWS00 Mfr#: LS27R750QEUXEN
The Samsung SR75 Series is designed to let you reclaim your work space. Occupying a minimum of desk space and leaving work areas clear when not in use, the Samsung monitor is the ideal solution wherever space is at a premium.
  • Space-saving design
    When not in use, the Samsung monitor pushes back to sit flat against a back wall to leave your entire work surface clear. When it's time for use, simply pull the Samsung monitor towards you and adjust to your preferred viewing position.
  • Concealed cables
    The Samsung monitor arm stand neatly conceals its power/HDMI cable in recessed channels to prevent tangling and keep your work space clear and free from clutter.
  • Stylish design
    With its slim panel featuring a 3-sided bezel-less screen, the Samsung monitor offers an understated stylish solution for any workplace or home interior.
  • Height-adjustable arm stand
    The Samsung monitor's zero-level height adjustable arm stand allows easy positioning of the screen for optimal comfort and convenience.
  • Adjustable eye level
    The Samsung monitor can be quickly and easily raised or lowered to the optimal viewing height of any user, making it a versatile solution for use at home or in public spaces such as libraries.
Samsung S27R750Q - SR75 Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class G
Energy Consumption per Year
70 kWh
Power Consumption (On mode)
48 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 144 Hz
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
1 billion colours
Colour Gamut
100% sRGB, 72% (NTSC 1976)
Input Connectors
HDMI, Mini DisplayPort
Display Position Adjustments
Height, tilt
Voltage
61.48 cm x 11.55 cm x 73.03 cm
5.8 kg
Display Type
Energy Class
Class G
70 kWh
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
1 billion colours
Colour Gamut
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, picture by picture, frameless, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Picture-in-Picture
61.48 cm x 11.55 cm x 73.03 cm - with stand
5.8 kg
HDMI , Mini DisplayPort
Mechanical
Height, tilt
Tilt Angle
-5/+20
Height Adjustment
213.9 mm
Dual Hinge stand
HDMI cable
Input Voltage
48 W
48 kWh/1000h
Power Consumption (Typical)
48 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Easy Setting Box
Dimensions & Weight Details
With stand - width: 61.48 cm - depth: 11.55 cm - height: 73.03 cm - weight: 5.8 kg , Without stand - width: 61.48 cm - depth: 2.6 cm - height: 36.21 cm - weight: 3.6 kg
Shipping Width
88.1 cm
Shipping Depth
15.9 cm
Shipping Height
44.8 cm
Shipping Weight
7.8 kg
10 °C
10 - 80% (non-condensing)
