The Samsung SR75 Series is designed to let you reclaim your work space. Occupying a minimum of desk space and leaving work areas clear when not in use, the Samsung monitor is the ideal solution wherever space is at a premium.
Space-saving design
When not in use, the Samsung monitor pushes back to sit flat against a back wall to leave your entire work surface clear. When it's time for use, simply pull the Samsung monitor towards you and adjust to your preferred viewing position. -
Concealed cables
The Samsung monitor arm stand neatly conceals its power/HDMI cable in recessed channels to prevent tangling and keep your work space clear and free from clutter. -
Stylish design
With its slim panel featuring a 3-sided bezel-less screen, the Samsung monitor offers an understated stylish solution for any workplace or home interior. -
Height-adjustable arm stand
The Samsung monitor's zero-level height adjustable arm stand allows easy positioning of the screen for optimal comfort and convenience. -
Adjustable eye level
The Samsung monitor can be quickly and easily raised or lowered to the optimal viewing height of any user, making it a versatile solution for use at home or in public spaces such as libraries.
- Samsung S27R750Q - SR75 Series - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Energy Consumption per Year
- 70 kWh
- Power Consumption (On mode)
- 48 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 144 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1 billion colours
- Input Connectors
- HDMI, Mini DisplayPort
- Height, tilt
- Black
- 61.48 cm x 11.55 cm x 73.03 cm
- 5.8 kg
- 2-year warranty
- Display Type
- Energy Class
- Class G
- 70 kWh
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- 1 billion colours
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, frameless, game mode, Mega Dynamic Contrast Ratio, 100% sRGB colour gamut, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, 72% (NTSC 1976) colour gamut, Picture-in-Picture, Picture-by-Picture
- Black
- 61.48 cm x 11.55 cm x 73.03 cm - with stand
- 5.8 kg
- HDMI , Mini DisplayPort
Mechanical
- Height, tilt
- Tilt Angle
- -5/+20
- Height Adjustment
- 213.9 mm
- Dual Hinge stand
- Cables Included
- HDMI cable
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 48 W
- Power Consumption SDR (On mode)
- 48 kWh/1000h
- Power Consumption (Typical)
- 48 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Included Software
- Easy Setting Box
- Dimensions & Weight Details
- With stand - width: 61.48 cm - depth: 11.55 cm - height: 73.03 cm - weight: 5.8 kg , Without stand - width: 61.48 cm - depth: 2.6 cm - height: 36.21 cm - weight: 3.6 kg
- Shipping Width
- 88.1 cm
- Shipping Depth
- 15.9 cm
- Shipping Height
- 44.8 cm
- Shipping Weight
- 7.8 kg
- Limited warranty - 2 years - carry-in
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
