Samsung S27H850 27" 2560x1440 4ms HDMI DP LED Monitor
With a USB type C port enabling you to transmit power and data easily
Quicklinx: D7DRWS00 Mfr#: LS27H850QFUXEN
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI
Select:
31 in stock
£324.43 ex VAT
£389.31 inc VAT
The SH85 is a just-right fit for any professional work environment. Its high-end PLS display, borderless on three sides, has a high pixel density, where texts are thoroughly vivid and images crystal clear without color shift, from whichever angle they are looked at. The SH85's daisy chain function allows extension and replication in multi-monitor settings with just a single DP cable connection. You can display its onscreen content on a second monitor at the same resolution. Communications in conference settings become a whole lot easier with the SH85.
Eye Saver mode reduces blue light emissions, which are known to cause damage to the retina, and in turn helps you minimize eye strain when working long hours, thus keeping your productivity afloat. Further, Flicker Free technology offers you a comfortable viewing experience. It swivels, tilts, pivots, and is height-adjustable, ready to meet the needs of any usage scenario. VESA-supported, it can be installed on a wall or separate arms with ease. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
  • Consistent colors at any viewing angle
  • Extend and duplicate with daisy chain
  • Eye Saver mode
  • Increase your ergonomic efficiency
Display Type
Energy Class
Class B
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
Diagonal Size
27"
Viewable Size
26.9"
Adaptive-Sync Technology
AMD FreeSync
Built-in Devices
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
1.07 billion colours
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, daisy chain compatible, Eye Saver Mode, Smart Eco Saving
61.19 cm x 23.6 cm x 54.37 cm - with stand
8 kg
HDMI , DisplayPort , Headphones , USB
Mechanical
Display Position Adjustments
Tilt Angle
-5/+24
Swivel Angle
90
Rotation Angle
94
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable
AC 120/230 V
40 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 61.19 cm - depth: 23.6 cm - height: 54.37 cm - weight: 8 kg , Without stand - width: 61.19 cm - depth: 7.72 cm - height: 36.61 cm - weight: 5.8 kg
10 °C
Samsung S27H850 27 Bundle deal on Samsung S27H850 27" 2560x1440 4ms HDMI DP LED Monitor
£423.60
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: 300 - 500
