Product
Samsung S27F358H 27" 1920x1080 4ms HDMI DP PLS LED Monitor
Quicklinx: D7D2WS00 Mfr#: LS27F358FWUXEN
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, HDMI
15 in stock
£164.59 ex VAT
£197.50 inc VAT
Samsung SF358 Series S27F358FWU LED monitor 27",1920 x 1080 Full HD. Plane to Line Switching, 250 cd/m², 1000:1 ,4 ms. Interfaces: HDMI and DisplayPort in high glossy black
Samsung SF358 Series S27F358FWU - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Tilt
High glossy black
62.62 cm x 24.26 cm x 46.61 cm
4.5 kg
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
27"
Viewable Size
27"
AMD FreeSync
Panel Type
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode, FreeSync Technology, 72% (NTSC 1976) colour gamut, Super Slim Design
High glossy black
62.62 cm x 24.26 cm x 46.61 cm - with stand
4.5 kg
DisplayPort , HDMI
Mechanical
Tilt
Tilt Angle
-2/+22
Flat Panel Mount Interface
75 x 75 mm
1 x HDMI cable
AC 120/230 V
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 62.62 cm - depth: 24.26 cm - height: 46.61 cm - weight: 4.5 kg , Without stand - width: 62.62 cm - depth: 7.63 cm - height: 36.49 cm - weight: 4 kg
10 °C
10 - 80% (non-condensing)
Samsung S27F358H 27 Bundle deal on Samsung S27F358H 27" 1920x1080 4ms HDMI DP PLS LED Monitor
£264.35
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: 150 - 300
