Samsung S27F350H 27" 1920x1080 4ms VGA HDMI PLS LED Monitor
Quicklinx: D7D1WS00 Mfr#: LS27F350FHUXEN
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
Select:
23 in stock
£151.30 ex VAT
£181.56 inc VAT
The Samsung SF350 monitor has a slim panel. Its simple circular stand elegantly complements the slender curved panel while its horizontal patterning on the rear panel provides a stylish, contemporary finish.
  • Optimized for viewing comfort
    The SF350 reduces blue light emissions - which stimulate the retina more than other color wavelengths and reduces eye fatigue to provide a more comfortable viewing experience.
  • Extra-wide viewing angles for the perfect view
    Enjoy extra-wide viewing angles that enable everyone to enjoy the perfect view from any position, whether sitting back to relax or gathered around with your friends.
Samsung S27F350FHU - SF350 Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Shiny black
62.62 cm x 24.77 cm x 46.24 cm
4.8 kg
Display Type
Energy Class
Class A
35 kWh
24 W
Diagonal Size
27"
AMD FreeSync
Panel Type
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eye Saver Mode, 72% (NTSC 1976) colour gamut
Shiny black
62.62 cm x 24.77 cm x 46.24 cm - with stand
4.8 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+22
VESA Mounting Interface
75 x 75 mm
AC 120/230 V
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 62.62 cm - depth: 24.77 cm - height: 46.24 cm - weight: 4.8 kg , Without stand - width: 62.62 cm - depth: 8.83 cm - height: 36.49 cm - weight: 4 kg
10 °C
10 - 80% (non-condensing)
Samsung S27F350H 27 Bundle deal on Samsung S27F350H 27" 1920x1080 4ms VGA HDMI PLS LED Monitor
£250.47
Diagonal Size: 27in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 150 - 300
