Samsung S27E650D 27" 1920x1080 4ms VGA DVI DisplayPort USB LED Monitor
Quicklinx: BKNJWS00 Mfr#: LS27E65UDS/EN
Samsung's S27E650D Eco-Friendly LCD monitor delivers an unmatched user experience, while maximizing energy-savings and sustainable design for reduced environmental impact.
Using the monitor's ECO-Power Off mode - a first-of-its-kind - the S27E650D offers 0.00W power consumption when in off mode. This is significantly lower than the 0.3W to 0.5W experienced with the average monitor, leading to significant savings in energy, resource and cost over time.
Along with superior power consumption, the monitor is designed with a 30 percent recycled plastic and PVC-free body. The recycled plastic and PVC-free body offer health and environmental benefits throughout the monitor's lifecycle, beginning with production, where it reduces the emission of harmful pollutants. During use, the monitor keeps PVC-related toxins out of the user's home, school and office. Finally, when correctly disposed, the monitor prevents PVC from leaking into soil, crops and water supplies.
Designed to be dustproof and waterproof, the OHD Series displays' components are also IP56 certified for superior performance even under the toughest conditions.
  • Ergonomic design
    With height, pivot, swivel, and tilt adjustments, the Samsung S27E650D offers an ergonomic design that ensures comfort during long hours of use. Its ability to adapt to various viewing positions makes it a suitable choice for professionals seeking a customizable viewing experience.
  • Enhanced visual clarity
    Featuring a 27-inch display with a 1920 x 1080 Full HD resolution, the monitor delivers vivid image clarity with 16.7 million colors and a high contrast ratio of 1000:1. LED backlight technology and Plane to Line Switching (PLS) provide bright, consistent colors across wide viewing angles of 178 degrees, enhancing the visual experience.
  • Advanced connectivity
    Equipped with DVI, DisplayPort, and VGA interfaces, this monitor offers versatile connectivity options to suit a wide range of devices. The built-in USB hub further enhances its functionality, allowing for easy connection of peripherals.
  • Eye comfort features
    The Samsung S27E650D is designed with your eye comfort in mind. Features like Eye Saver Mode, Flicker-Free technology, and an Off Timer Plus function work together to reduce eye strain during extended use, making it a suitable choice for users who spend long hours in front of the screen.
Samsung S27E650D - SE650 Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (NTSC 1976)
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
63.9 cm x 22.4 cm x 40.28 cm
6.92 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
3-year warranty
Display Type
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (NTSC 1976)
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
63.9 cm x 22.4 cm x 40.28 cm - with stand
6.92 kg
VGA , DVI , DisplayPort , 2 x USB
Mechanical
Tilt Angle
-4/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
PVC free
1 x VGA cable , 1 x USB cable
Input Voltage
AC 120/230 V
Power Consumption (Typical)
20 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 63.9 cm - depth: 22.4 cm - height: 40.28 cm - weight: 6.92 kg , Without stand - width: 63.9 cm - depth: 5.76 cm - height: 37.81 cm - weight: 5.2 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
