Samsung S27E650C 27" 1920x1080 4ms DVI HDMI DisplayPort USB LED Monitor
Quicklinx: BKNMWS00 Mfr#: LS27E65KCS/EN
The Samsung LED Business Monitor SE650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SE650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SE650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SE650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SE650 is ready to deliver an efficient and clean work space. The SE650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SE650.
The Samsung LED Business Monitor SE650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce ways of working. The SE650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SE650.
  • Better user comfort with curved screen
    The curved screen provides an easily noticeable increase in comfort for your employees. They'll enjoy less eye fatigue and a better viewing experience. Plus, the Eye Saver mode reduces the amount of Blue light usage - leading to less eye strain.
  • Environmentally friendly
    With approximately 30% recycled plastic, less than 0.005W off-mode power consumption, Eco features to reduce power consumption when the monitor is in use and fully recyclable packaging, this is the perfect monitor for the environmentally-conscious business.
  • Ergonomic, adjustable stand
    Experience the new standard in monitor design. The stand swivels, tilts, pivots and is height-adjustable, all in a smooth manner. And since the monitor is VESA compatible, installation on a wall or separate mounting arms is easy.
  • Fast, easy connectivity
    DVI, HDMI and Display Port provide flexibility in high-speed connectivity. And 4 USB ports allow for easy connection to peripherals. So whatever devices your employees need to connect today or in the future, this monitor keeps everyone's options open.
Samsung S27E650C - SE650 Series - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Curved Screen
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
62.32 cm x 25.74 cm x 41.49 cm
7.3 kg
Environmental Standards
ENERGY STAR Qualified
EN55022, IEC 60950, EN55024, FCC Part 15 B, AS/NZS 3548, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, VCCI V-3, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, IEC60950-1, GB 17625.1-2003
3-year warranty
Display Type
Energy Class
Class A
44 kWh
Diagonal Size
27"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72%
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eye Saver Mode, Smart Eco Saving
62.32 cm x 25.74 cm x 41.49 cm - with stand
7.3 kg
DVI , DisplayPort , HDMI , Headphones , 4 x USB
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Rotation Angle
-1.5/+91.5
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable
30 W
Power Consumption (Typical)
20.6 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Easy Setting Box
Windows 8.1
Dimensions & Weight Details
With stand - width: 62.3 cm - depth: 25.74 cm - height: 41.49 cm - weight: 7.3 kg , Without stand - width: 62.32 cm - depth: 6.29 cm - height: 37.57 cm - weight: 4.9 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
