Samsung S27E510C 27" 1920x1080 4ms VGA HDMI Curved LED Monitor
Quicklinx: B8L7WS00 Mfr#: LS27E510CS/EN
With thoughtful design and engineering, the SE510C is much more than a monitor with stunning looks. Featuring a glossy black body that is framed perfectly by a narrow bezel and elevated by a T-shaped stand, it's carefully designed to keep the focus on your content viewing pleasure.
Samsung S27E510C - SE510C Series - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
54 kWh
Power Consumption (On mode)
37 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Shiny black
62.32 cm x 18.16 cm x 46.3 cm
5.52 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
54 kWh
Diagonal Size
27"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
Shiny black
62.32 cm x 18.16 cm x 46.3 cm - with stand
5.52 kg
VGA , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-2/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Power Supply
External
Input Voltage
AC 120/230 V
37 W
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 62.32 cm - depth: 18.16 cm - height: 46.3 cm - weight: 5.52 kg , Without stand - width: 62.32 cm - depth: 5.99 cm - height: 36.57 cm - weight: 4.91 kg
Sustainability Information
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
