Samsung S27E391H 27" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: BWXKWS00 Mfr#: LS27E391HS/EN
Select:
  • 27"
Define your space with a stylish new design accentuated by slim bezels and soft blue light
  • New Slim ToC: With a beautiful new semi-transparent blue finish, Samsung’s innovative Touch of Color technology optimizes your living space and completely sets it apart.
  • Slim Narrow Bezel: The bezels on all four sides are super slim, especially the one running along the bottom. Not only does it deliver a clean and modern look, it naturally draws your eyes to the screen.
  • T-Shaped Stand: Using Touch of Color for the T-shape stand completes the ensemble with a refined, minimal finish.
Brilliant picture quality for the optimal viewing experience
  • Wide Viewing Angle: Delivers a 178° wide viewing angle horizontally and vertically for an optimal and comfortable viewing experience from any angle.
  • FHD: Provides clean and crisp picture quality in 1920x1080 resolution.
Easy on the eyes for a more comfortable viewing experience
  • Eye Saver Mode: Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue.
  • Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy and the environment with this eco-friendly monitor
  • Eco Saving Plus: Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (Minimum at 25% and Maximum at 50%), there is now a brand new Auto Setting that reduces energy up about 10%*, based on the luminescence of the screen’s black sections.
  • PVC Free: Monitor mechanisms and circuits are constructed without PVC making for an eco-friendly device, lessening environmental impact. (Some Cables may include PVC).
Enjoy smooth images even during fast moving scenes
  • A truly fast 4ms response time lets you see even the fastest on-screen motion clearly and smoothly with less motion blur, judder and ghosting.
Upscale your view with better quality and picture
  • Magic Upscale improves resolution of lower quality images and video so you can enjoy enhanced quality regardless of the original source.
  • Slim ToC
    With a beautiful semi-transparent finish, Samsung's Touch of Color technology optimizes your living space and completely sets it apart.
  • Slim narrow bezel
  • T-shaped stand
    Using touch of color for the T-shape stand completes the ensemble with a refined, minimal finish.
  • Wide viewing angle
  • FHD
    Provides clean and crisp picture quality in 1920 x 1080 resolution.
  • Eye saver mode
    Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye saver mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free technology
  • Enjoy smooth images even during fast moving scenes
    A truly fast 4 ms response time lets you see even the fastest on-screen motion clearly and smoothly with less motion blur, judder, and ghosting.
  • Upscale your view with better quality and picture
    Magic upscale improves resolution of lower quality images and video so you can enjoy enhanced quality regardless of the original source.
Samsung S27E391H - SE391 Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
26 W
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
White glossy
62.6 cm x 18.19 cm x 45.29 cm
5.14 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class A
37 kWh
Diagonal Size
27"
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, Touch of Color (ToC), game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
White glossy
62.6 cm x 18.19 cm x 45.29 cm - with stand
5.14 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-2/+15
PVC free
1 x VGA cable
Power Supply
External
Input Voltage
AC 120/230 V
26 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 62.6 cm - depth: 18.19 cm - height: 45.29 cm - weight: 5.14 kg , Without stand - width: 62.6 cm - depth: 7.08 cm - height: 37.72 cm - weight: 4.58 kg
Sustainability Information
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
