Samsung SE370D is the monitor with an integrated wireless charging function for mobile devices. With the diagonal size of 27 inches, this monitor declutters work areas by doing away with unnecessary cables and ports needed to charge mobile devices. Along with superior picture quality, enhanced visual performance and thoughtful design, the monitor seamlessly integrates advanced technologies that offer both professionals and consumers an optimal viewing and usability experience.
Convenient wireless mobile charging
For optimized convenience and productive multitasking, this monitor consolidates the multiple charging ports found in other displays with a circular wireless charging area integrated in the monitor's stand. Users simply need to place their device on the stand's charging area to initiate automatic charging, which is confirmed by an LED light. As a complete solution, the SE370D eliminates the hassle of having to purchase and keep separate charging kits, saving cost and improving workspace utilization. Users also can continue working while their mobile devices charge, helping them to enhance productivity and work task efficiency. -
Comfortable viewing and superior picture quality
Designed for extended periods of screen use, Samsung's SE370D makes the viewing experience less strenuous. The monitor's eye-saver mode reduces the harmful effects of blue light on viewers' eyes and associated eye strain by monitoring and optimizing picture quality to match specific environmental settings. Similarly, the monitor's flicker-free function protects viewers' eyes from the constant strain of flickering screens that can occur with standard monitors. The SE370D further ensures comfortable viewing through a high-performance Plane-to-Line-Switching (PLS) panel. The PLS panel allows users to experience universally-optimized viewing with a 178-degree wide-viewing angle, as well as excellent picture quality with vivid and clear imagery delivered through a high brightness. -
Improved gaming experience
Complementary to these embedded picture-enhancing functions, the SE370D delivers a smooth, non-distracting and immersive entertainment experience. Supported by FreeSync technology, the monitor synchronizes the screen refresh rate with the frame rate of a user's AMD graphics card to minimize input latency, as well as to reduce stutter and lag during gaming and video playback. Additionally, the SE370D monitor's fast response time enables clear and smooth tracking of even extra fast on-screen action without motion blur or ghosting, while a unique game mode quickly activates with the touch of a button. The monitor's game mode detects changes in scenes and instantly corrects blurry images, enhances colors and alters contrast for improved visibility. -
Energy efficiency and design sophistication
The monitor's improved Eco Saving Plus function reduces screen brightness for increased energy efficiency. In addition to two manual settings, an auto-setting reduces energy consumption based on the luminescence of the screen's black sections in auto on-screen display (OSD) mode. For decreased environmental impact, the monitor's front cover, stand and circuits also are constructed without PVC. Along with being an eco-friendly device, the SE370D adds a modern aesthetic and pleasing appearance to homes and workspaces. An ultra-narrow bezel and semi-transparent frame the monitor's sleek, glossy body on all four sides for a clean look. Featuring Samsung's Touch of Color accents, a T-shaped stand accentuates the monitor's impactful design with a refined and minimal finish.
- Samsung S27E370D - SE370 Series - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 41 kWh
- Power Consumption (On mode)
- 28 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- High glossy white
- 62.6 cm x 19.69 cm x 46.1 cm
- 5.2 kg
- Qi
- Display Type
- Energy Class
- Class A
- 41 kWh
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, super narrow frame, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
- High glossy white
- 62.6 cm x 19.69 cm x 46.1 cm - with stand
- 5.2 kg
- VGA , HDMI , DisplayPort , Headphones
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- Qi Wireless Charging, PVC free
- Cables Included
- 1 x VGA cable
- Qi
- 28 W
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Windows 10
- Dimensions & Weight Details
- With stand - width: 62.6 cm - depth: 19.69 cm - height: 46.1 cm - weight: 5.2 kg , Without stand - width: 62.6 cm - depth: 7.08 cm - height: 37.72 cm - weight: 4.7 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
