Samsung S27E330H 27" 1920x1080 1ms HDMI VGA LED Monitor
Quicklinx: D7CYWS00 Mfr#: LS27E330HZX/EN
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
24 in stock
£130.04 ex VAT
£156.04 inc VAT
Instantly optimizing screen colors and contrast for gaming, Game Mode ensures you get to see game scenes at their best. Eye Saver Mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (Minimum at 25% and Maximum at 50%), there is now a brand new Auto Setting that reduces energy up about 10%, based on the luminescence of the screen's black sections. The screen brightness transitions fluidly while simultaneously saving energy. Monitor mechanisms and circuits are constructed without PVC making for an eco-friendly device, lessening environmental impact.
  • Experience darker blacks with Game Mode
  • Easy on the eyes for a more comfortable viewing experience
  • Save energy and the environment with this eco-friendly monitor
    Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (Minimum at 25% and Maximum at 50%), there is now a brand Auto Setting that reduces energy up about 10%, based on the luminescence of the screen's black sections. The screen brightness transitions fluidly while simultaneously saving energy. Monitor mechanisms and circuits are constructed without PVC making for an eco-friendly device, lessening environmental impact.
Samsung S27E330H - SE310 Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
64.34 cm x 20.07 cm x 46.31 cm
5.1 kg
Display Type
Energy Class
Class B
48 kWh
33 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, 72% (NTSC 1976) colour gamut
64.34 cm x 20.07 cm x 46.31 cm - with stand
5.1 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+20
VESA Mounting Interface
75 x 75 mm
1 x HDMI cable
AC 120/230 V
35 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 64.34 cm - depth: 20.07 cm - height: 46.31 cm - weight: 5.1 kg , Without stand - width: 64.34 cm - depth: 9.51 cm - height: 38.53 cm - weight: 4.7 kg
10 °C
10 - 80% (non-condensing)
Samsung S27E330H 27 Bundle deal on Samsung S27E330H 27" 1920x1080 1ms HDMI VGA LED Monitor
£229.21
Diagonal Size: 27in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 100 - 150
