Samsung S27D850D 27" 2560x1440 5ms DVI HDMI DisplayPort USB LED Monitor
Quicklinx: B4RKWS00 Mfr#: LS27D85KTSN/XU
The ergonomics of the SD850 helps make your professional work space convenient and comfortable. Samsung's height adjustable stand (HAS) design lets you adjust the monitor height by up to 130mm. You can pivot, swivel, and tilt to adjust the perspective from horizontal to vertical. It even supports Auto OSD Rotation so you don't have to change the aspect ratios when you want to pivot your screen.
The SD850 features a bezel that helps provide a deeply immersive viewing experience that lets you concentrate on the tasks at hand.
View from various angles with the SD850. The Samsung LED Monitor has a wide viewing angle, vertically and horizontally.
With Picture-by-Picture (PBP), you can connect two compatible PCs to the same monitor and see the desktops of both simultaneously on one screen that's divided into two. Thanks to PBP and the WQHD resolution size you won't have to worry about losing the picture quality and resolution. Plug in your compatible laptop and your desktop and use both without needing to keep looking between different monitors - it's all there at a glance.
Samsung's latest Picture-in-Picture 2.0 technology lets you multi-task and watch videos. Whether it's 720p or 480p, PIP 2.0 doesn't downscale contents and helps maintain the same resolution as clear and crisp on its own. It supports resolutions up to HD and you can adjust the PIP resolution and position to help fit your needs.
The SD850's light sensor adjusts the screen brightness to help match your environment so that the screen is visible in a range of lighting conditions.
  • WQHD 2560 x 1440 resolution
    At nearly twice the resolution of a standard monitor, the 27" S27D850T allows you to see more, more clearly. With more resolution, smaller fonts are legible, and details in photos, videos and illustrations are more discernible.
  • 100% sRGB color compliance
    For those professionals who depend on accurate color, the S27D850T is 100% sRGB compliant. From conception to output, your color will be exactly the color you specify. Plus, with a 178-degree wide viewing panel, the image is clearly viewable at off angles.
  • Split screen and picture in picture
    Twice the resolution allows twice the screen information. With split screen and PIP, you can view two distinct video inputs simultaneously. Code in one window and see the results in the other. Compare your photo or document revisions with the original while you work. Read your email in one screen while editing a document in the other.
  • Ergonomic and slim bezel design
    The SD850 series monitors deliver not only great image performance, but also enhanced ergonomics and a beautiful, beveled slim-bezel design that looks great, on or off. Enhance your productivity and your desk with the Samsung SD850 series monitor.
Samsung S27D850T - 8 Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
67 kWh
Power Consumption (On mode)
46 W
USB 3.0 hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-I, DisplayPort
Display Position Adjustments
Voltage
Titanium silver, matte black
62.74 cm x 28 cm x 46.63 cm
9.95 kg
Environmental Standards
ENERGY STAR Qualified
TUV, C-Tick, EN55022, EN55024, CB, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, FCC Part 15 B Class A, VCCI V-3, GB 17625.1-2003 EMC, KCC KN22, KCC KN24, GB 9254, GB4943.1-2001
3-year warranty
Display Type
Energy Class
Class C
67 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, MagicBright 3, game mode, Eco Light Sensor, Eco Saving, Magic Upscale, Ultra-Flexible Height Adjustment System (HAS), Mercury free, Image Size, PIP 2.0, PBP, USB Super-charging, OSD Auto Rotate
62.74 cm x 28 cm x 46.63 cm - with stand
9.95 kg
DVI-I (dual link) , HDMI , DisplayPort , Headphones , Audio line-in , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x DVI cable , 1 x USB cable , 1 x DisplayPort cable
Power Supply
Internal
Input Voltage
46 W
Power Consumption (Typical)
90 Watt
Power Consumption Stand by
0.5 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 62.74 cm - depth: 28 cm - height: 46.63 cm - weight: 9.95 kg , Without stand - width: 62.74 cm - depth: 6.61 cm - height: 37.64 cm - weight: 7.1 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
B4RK C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
