The ergonomics of the SD850 helps make your professional work space convenient and comfortable. Samsung's height adjustable stand (HAS) design lets you adjust the monitor height by up to 130mm. You can pivot, swivel, and tilt to adjust the perspective from horizontal to vertical. It even supports Auto OSD Rotation so you don't have to change the aspect ratios when you want to pivot your screen.
The SD850 features a bezel that helps provide a deeply immersive viewing experience that lets you concentrate on the tasks at hand.
View from various angles with the SD850. The Samsung LED Monitor has a wide viewing angle, vertically and horizontally.
With Picture-by-Picture (PBP), you can connect two compatible PCs to the same monitor and see the desktops of both simultaneously on one screen that's divided into two. Thanks to PBP and the WQHD resolution size you won't have to worry about losing the picture quality and resolution. Plug in your compatible laptop and your desktop and use both without needing to keep looking between different monitors - it's all there at a glance.
Samsung's latest Picture-in-Picture 2.0 technology lets you multi-task and watch videos. Whether it's 720p or 480p, PIP 2.0 doesn't downscale contents and helps maintain the same resolution as clear and crisp on its own. It supports resolutions up to HD and you can adjust the PIP resolution and position to help fit your needs.
The SD850's light sensor adjusts the screen brightness to help match your environment so that the screen is visible in a range of lighting conditions.
WQHD 2560 x 1440 resolution
At nearly twice the resolution of a standard monitor, the 27" S27D850T allows you to see more, more clearly. With more resolution, smaller fonts are legible, and details in photos, videos and illustrations are more discernible. -
100% sRGB color compliance
For those professionals who depend on accurate color, the S27D850T is 100% sRGB compliant. From conception to output, your color will be exactly the color you specify. Plus, with a 178-degree wide viewing panel, the image is clearly viewable at off angles. -
Split screen and picture in picture
Twice the resolution allows twice the screen information. With split screen and PIP, you can view two distinct video inputs simultaneously. Code in one window and see the results in the other. Compare your photo or document revisions with the original while you work. Read your email in one screen while editing a document in the other. -
Ergonomic and slim bezel design
The SD850 series monitors deliver not only great image performance, but also enhanced ergonomics and a beautiful, beveled slim-bezel design that looks great, on or off. Enhance your productivity and your desk with the Samsung SD850 series monitor.
- Samsung S27D850T - 8 Series - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 67 kWh
- Power Consumption (On mode)
- 46 W
- USB 3.0 hub
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-I, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Titanium silver, matte black
- 62.74 cm x 28 cm x 46.63 cm
- 9.95 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV, C-Tick, EN55022, EN55024, CB, CCC, PSB, AS/NZS 3548, UL 60950-1, IEC 60950-1, FCC Part 15 B Class A, VCCI V-3, GB 17625.1-2003 EMC, KCC KN22, KCC KN24, GB 9254, GB4943.1-2001
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 67 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, MagicBright 3, game mode, Eco Light Sensor, Eco Saving, Magic Upscale, Ultra-Flexible Height Adjustment System (HAS), Mercury free, Image Size, PIP 2.0, PBP, USB Super-charging, OSD Auto Rotate
- 62.74 cm x 28 cm x 46.63 cm - with stand
- 9.95 kg
- DVI-I (dual link) , HDMI , DisplayPort , Headphones , Audio line-in , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 60
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x DVI cable , 1 x USB cable , 1 x DisplayPort cable
- Power Supply
- Internal
- Input Voltage
- 46 W
- Power Consumption (Typical)
- 90 Watt
- Power Consumption Stand by
- 0.5 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 62.74 cm - depth: 28 cm - height: 46.63 cm - weight: 9.95 kg , Without stand - width: 62.74 cm - depth: 6.61 cm - height: 37.64 cm - weight: 7.1 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
