It takes a special kind of design to really make the most of your monitor's picture. Constructed from sophisticated metallic materials, the Samsung SD590 was created by the meeting of lines, with a clean and understated look that ensures nothing will distract you from the screen. Elevated by a sleek stand and neck, the picture almost seems to float weightlessly, framed perfectly by a super narrow bezel, and the monitor's clean back enhances its elegant silhouette.
Design like no other for a completely new level of viewing pleasure
It takes a special kind of design to really make the most of your monitor's picture. Constructed from sophisticated metallic materials, the Samsung SD590 was created by the meeting of lines, with a clean and understated look that ensures nothing will distract you from the screen. Elevated by a sleek stand and neck, the picture almost seems to float weightlessly, framed perfectly by a super narrow bezel, and the monitor's clean back enhances its elegant silhouette. -
Bring beautiful simplicity into your life with space-saving minimalist design
Simplicity can make life easier and more peaceful. The Samsung SD590 monitor helps you achieve that, thanks to a design that's both practical and beautiful. Its elegantly minimal T-shaped stand has been carefully developed to use as little space as possible, giving you more room and reducing clutter. -
Enhance your gaming experience with just one button
Get perfect viewing for games with just one touch of a button. Game mode adjusts your monitor's settings instantly to give you an optimized gaming experience. Game mode smartly detects the changes in scenes, enhances the color and alters the screen's contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won't let you down.
- Samsung S27D590P - SD590 Series - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 44 kWh
- Power Consumption (On mode)
- 30 W
- Panel Type
- AD-PLS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- High glossy black
- 61.95 cm x 16.92 cm x 46.5 cm
- 4.96 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class A
- 44 kWh
- Diagonal Size
- 27"
- Panel Type
- AD-PLS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Safe, Mercury free, Image Size
- High glossy black
- 61.95 cm x 16.92 cm x 46.5 cm - with stand
- 4.96 kg
- VGA , 2 x HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -1/+15
- Cables Included
- 1 x HDMI cable
- Power Supply
- External
- Input Voltage
- 30 W
- Power Consumption (Typical)
- 33 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 61.95 cm - depth: 16.92 cm - height: 46.5 cm - weight: 4.96 kg , Without stand - width: 61.95 cm - depth: 5.85 cm - height: 38.86 cm - weight: 4.36 kg
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
