Samsung S27D590P 27" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: BKN8WS00 Mfr#: LS27D590PSX/XU
It takes a special kind of design to really make the most of your monitor's picture. Constructed from sophisticated metallic materials, the Samsung SD590 was created by the meeting of lines, with a clean and understated look that ensures nothing will distract you from the screen. Elevated by a sleek stand and neck, the picture almost seems to float weightlessly, framed perfectly by a super narrow bezel, and the monitor's clean back enhances its elegant silhouette.
  • Design like no other for a completely new level of viewing pleasure
  • Bring beautiful simplicity into your life with space-saving minimalist design
    Simplicity can make life easier and more peaceful. The Samsung SD590 monitor helps you achieve that, thanks to a design that's both practical and beautiful. Its elegantly minimal T-shaped stand has been carefully developed to use as little space as possible, giving you more room and reducing clutter.
  • Enhance your gaming experience with just one button
    Get perfect viewing for games with just one touch of a button. Game mode adjusts your monitor's settings instantly to give you an optimized gaming experience. Game mode smartly detects the changes in scenes, enhances the color and alters the screen's contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won't let you down.
Samsung S27D590P - SD590 Series - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Panel Type
AD-PLS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Voltage
High glossy black
61.95 cm x 16.92 cm x 46.5 cm
4.96 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class A
44 kWh
Diagonal Size
27"
Panel Type
AD-PLS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Safe, Mercury free, Image Size
High glossy black
61.95 cm x 16.92 cm x 46.5 cm - with stand
4.96 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-1/+15
1 x HDMI cable
Power Supply
External
Input Voltage
30 W
Power Consumption (Typical)
33 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 61.95 cm - depth: 16.92 cm - height: 46.5 cm - weight: 4.96 kg , Without stand - width: 61.95 cm - depth: 5.85 cm - height: 38.86 cm - weight: 4.36 kg
Sustainability Information
ENERGY STAR Certified
BKN8 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
