Samsung S24H850 24" 2560x1440 5ms HDMI DP LED Monitor
With a USB type C port enabling you to transmit power and data easily
Quicklinx: D7DQWS00 Mfr#: LS24H850QFUXEN
Diagonal Size: 24in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI
Select:
Hurry, only 2 left in stock!
£230.99 ex VAT
£277.18 inc VAT
The SH85 is a just-right fit for any professional work environment. Its high-end PLS display, borderless on three sides, has a high pixel density, where texts are thoroughly vivid and images crystal clear without color shift, from whichever angle they are looked at. The SH85's daisy chain function allows extension and replication in multi-monitor settings with just a single DP cable connection. You can display its onscreen content on a second monitor at the same resolution. Communications in conference settings become a whole lot easier with the SH85.
Eye Saver mode reduces blue light emissions, which are known to cause damage to the retina, and in turn helps you minimize eye strain when working long hours, thus keeping your productivity afloat. Further, Flicker Free technology offers you a comfortable viewing experience. It swivels, tilts, pivots, and is height-adjustable, ready to meet the needs of any usage scenario. VESA-supported, it can be installed on a wall or separate arms with ease. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
  • Consistent colors at any viewing angle
  • Extend and duplicate with daisy chain
  • Eye Saver mode
  • Increase your ergonomic efficiency
Samsung S24H850QFU - SH850 Series - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
Adaptive-Sync Technology
AMD FreeSync
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
54.04 cm x 23.6 cm x 52.31 cm
6.4 kg
Display Type
Energy Class
Class C
55 kWh
38 W
Diagonal Size
24"
Viewable Size
23.8"
AMD FreeSync
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, daisy chain compatible, Eye Saver Mode, Smart Eco Saving
54.04 cm x 23.6 cm x 52.31 cm - with stand
6.4 kg
HDMI , DisplayPort , Headphones , USB
Mechanical
Tilt Angle
-5/+24
Swivel Angle
90
Rotation Angle
94
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
AC 120/230 V
38 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.04 cm - depth: 23.6 cm - height: 52.31 cm - weight: 6.4 kg , Without stand - width: 54.04 cm - depth: 7.74 cm - height: 32.35 cm - weight: 4.1 kg
10 °C
Samsung S24H850 24 Bundle deal on Samsung S24H850 24" 2560x1440 5ms HDMI DP LED Monitor
£330.16
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: 150 - 300
