Samsung S24H650FDU 23.6" 1920x1080 5ms VGA HDMI DP PLS LED Monitor
Quicklinx: D7DFWS00 Mfr#: LS24H650FDUXEN
Select:
  • 23.8"
The SH650 Series is a just-right fit for any professional work environment, with its high-end PLS panel whereon texts are thoroughly vivid and images crystal clear, without color shift, from whichever angle they are looked at.
The Eye Saver Mode reduces blue light emissions, which are known to cause damage to the retina and in turn helps you minimize eye strain when working long hours, thus keeping your productivity afloat. Further, the Flicker Free technology offers you a comfortable viewing experience.
The SH650 Series monitor swivels, tilts, pivots and is height-adjustable, ready to meet the needs of any usage scenario. VESA-supported, it can be installed on a wall or separate arms with ease. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
The SH650 Series comes with power-saving modes including SMART Eco Saving which automatically adjusts the brightness of the display based on the colors displayed, and the zero-watt consumption function that brings down power consumption to practically nil when the screen is turned off.
The SH650 provides multi-connectivity with D-sub, DP, HDMI and USB ports on the back of the monitor, prepared to be connected with whatever devices your team or your client chooses to connect for better business outcomes.
  • Consistent colors at any viewing angle
  • Long-lasting eye comfort
  • Built to fit your business space
  • Smart cost saver
  • Multiple-connectivity
Samsung S24H650FDU - SH65 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
55.62 cm x 23.6 cm x 52.52 cm
6.1 kg
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Infinity Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
55.62 cm x 23.6 cm x 52.52 cm - with stand
6.1 kg
VGA , HDMI , DisplayPort , Headphones
Mechanical
Tilt Angle
-5/+24
Swivel Angle
90
Rotation Angle
-2/+92
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
Input Voltage
AC 120/230 V
20 W
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Dimensions & Weight Details
With stand - width: 55.62 cm - depth: 23.6 cm - height: 52.52 cm - weight: 6.1 kg , Without stand - width: 55.62 cm - depth: 7.67 cm - height: 33.03 cm - weight: 3.9 kg
10 °C
10 - 80% (non-condensing)
