Samsung S24E650C 23.5" 1920x1080 4ms DVI HDMI DisplayPort USB LED Monitor
Quicklinx: BKNLWS00 Mfr#: LS24E65KCS/EN
The Samsung LED Business Monitor SE650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SE650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SE650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SE650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SE650 is ready to deliver an efficient and clean work space. The SE650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SE650.
The Samsung LED Business Monitor SE650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce ways of working. The SE650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SE650.
  • A business tool that produces crystal-clear images
    The Samsung Business Monitor produces the highest level of static contrast ratio of 3,000:1. Compared to competitive models in the same class, the Samsung Business Monitor possesses a contrast ratio that is three times higher. This provides users with clear and sharp image representation which is a strong benefit for businesses that work heavily around graphics and other high-resolution images.
  • A monitor designed to match business needs
  • Maximize workspace with the efficient handle VESA wall mount
  • Conveniently adjust monitor height, tilt, and perspective
    The Samsung LED Business Monitor SE650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SE650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SE650.
  • Save energy and see the results with the energy tree
    Take the guess work out of eco savings with Samsung Energy Tree feature. For the first time, you can now know exactly how much energy you are saving through your eco modes such as the Eco light sensor and the Eco motion sensor. Through an intuitive energy saving status, which can be displayed either intuitively or graphically, you can keep tabs on your efforts to make the world a better place.
  • Control power consumption, conserve energy
    Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung's commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
  • Gentle on the eyes and on the environment
    Save electricity and hassle with Samsung's Eco light sensor. By adjusting screen brightness to match your surrounding environment, the SE650's Eco light sensor creates a brilliant visual display while also minimizing your energy consumption. You will benefit from a more comfortable viewing experience that is far better for the environment. Monitor brightness is adjusted to match your ambient light, which ensures that the screen is highly visible and appropriately set for your eyes. So, in a dark room the screen will reduce brightness, but when sitting in a room with plenty of light, it will increase brightness. The Eco light sensor is simply perfect for modern living - helping you conserve energy and keep comfortable.
  • Save energy with smart motion technology
    Step into the future with the SE650 monitor, which utilizes the very latest in motion sensors to create a monitor that hangs on your every movement. With a built-in PIR (Pyrolectric Infrared Ray) sensor, the SE650 automatically detects movement within a specified area in front of the screen. This allows your monitor to automatically dim or power off, and then power back on or brighten once detecting a nearby viewer. Eco motion sensor is the easiest way to conserve energy.
  • See your work from the best possible angle
    Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung Business Monitor. While conventional monitors have a viewing angle of 170 degrees horizontally, the Samsung monitor has an extra wide viewing angle of 178 degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung Business Monitor has improved its vertical viewing angles by 18 degrees, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video.
Samsung S24E650C - SE650 Series - LED monitor - curved - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
Curved Screen
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27156 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Black, hairline
54.78 cm x 25.74 cm x 39.24 cm
6.2 kg
Environmental Standards
ENERGY STAR Qualified
EN55022, IEC 60950, EN55024, FCC Part 15 B, AS/NZS 3548, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, VCCI V-3, GB 9254-2008, NOM-019-SCFI-1998, K60950-1, KCC KN22, KCC KN24, IEC60950-1, GB 17625.1-2003
3-year warranty
Display Type
Energy Class
Class B
45 kWh
Diagonal Size
24"
Viewable Size
23.5"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27156 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72%
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, power off timer, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eye Saver Mode, Smart Eco Saving
Black, hairline
54.78 cm x 25.74 cm x 39.24 cm - with stand
6.2 kg
DVI , DisplayPort , HDMI , Headphones , 4 x USB
Mechanical
Tilt Angle
-5/+20
Swivel Angle
60
Rotation Angle
-1.5/+91.5
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable
31 W
Power Consumption (Typical)
21.6 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Easy Setting Box
Windows 8.1
Dimensions & Weight Details
With stand - width: 54.78 cm - depth: 25.74 cm - height: 39.24 cm - weight: 6.2 kg , Without stand - width: 54.78 cm - depth: 6.14 cm - height: 33.34 cm - weight: 3.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
