Samsung S24E450DL 23.6" 1920x1080 5ms VGA DVI DisplayPort USB LED Monitor
Quicklinx: BKMTWS00 Mfr#: LS24E45UDLC/EN
The SE450 Series provides an environmentally-friendly, user-friendly and budget-friendly yet high-quality desktop monitor solution for your business. The features of this 23.6" monitor include a simple and easy-to-use design, fully-adjustable stand, matte bezel with clearly-labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
  • Environmentally-friendly
    With recycled plastic, less than 0.005 W off-mode power consumption, Eco features to reduce power consumption when the monitor is in use and fully-recyclable packaging, this is the perfect value monitor for the environmentally-conscious business.
  • Impressive picture quality
    The LED-backlit LCD screen delivers sharp, bright and beautiful images. Mega infinity dynamic contrast ratio helps to ensure subtle detail even in the lights and darks, and MagicAngle technology delivers quality color even when viewed off-angle.
  • Slim design that fits any desk
    The sleek, stylish design and low profile stand take up less desk space and contribute to a cleaner-looking office. The built-in cable management feature also adds to a clutter-free work environment.
  • Ergonomic, adjustable stand
    The monitor swivels, tilts, pivots and is height-adjustable.
  • Fast, easy connectivity
    VGA and DVI provide flexibility in high-speed connectivity. So whatever devices your employees need to connect today or in the future, this monitor keeps everyone's possibilities open.
Samsung S24E450DL - SE450 Series - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
55.46 cm x 22.4 cm x 35.73 cm
5.63 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
3-year warranty
Display Type
Diagonal Size
23.6"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
55.46 cm x 22.4 cm x 35.73 cm - with stand
5.63 kg
VGA , DVI , DisplayPort , 2 x USB
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
PVC free
1 x DisplayPort cable , 1 x USB cable
AC 120/230 V
22 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Dimensions & Weight Details
With stand - width: 55.46 cm - depth: 22.4 cm - height: 35.73 cm - weight: 5.63 kg , Without stand - width: 55.46 cm - depth: 5.54 cm - height: 33.05 cm - weight: 3.97 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
BKMT StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.28
BKMT StarTech.com Dual Monitor Stand In Stock £70.24
BKMT StarTech.com Cubicle Monitor Hanger In Stock £46.01
BKMT StarTech.com Monitor Arm - Heavy Duty In Stock £73.69
