The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Environmentally friendly
With 30% recycled plastic, less than 0.005 W off-mode power consumption, Eco features to reduce power consumption when the monitor is in use and fully recyclable packaging, this is the perfect value monitor for the environmentally-conscious business. -
Impressive picture quality
The LED-backlit LCD screen delivers sharp, bright and beautiful images. Mega infinity dynamic contrast ratio helps to ensure subtle detail even in the lights and darks, and MagicAngle technology delivers quality color even when viewed off-angle. -
Slim design that fits any desk
The sleek, stylish design and low profile stand take up less desk space and contribute to a cleaner-looking office. The built-in cable management feature also adds to a clutter-free work environment. -
Ergonomic, adjustable stand
The monitor swivels, tilts, pivots and is height-adjustable. And since it is VESA compatible, installation on a wall or separate mounting arms is easy. -
Fast, easy connectivity
VGA, DVI and DisplayPort provide flexibility in high-speed connectivity. So whatever devices your employees need to connect today or in the future, this monitor keeps everyone's options open.
- Samsung S24E450B - SE450 Series - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class G
- Power Consumption (On mode)
- 27 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.27675 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (NTSC 1976)
- Input Connectors
- DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- 56.54 cm x 22.4 cm x 35.68 cm
- 5.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27675 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72% (NTSC 1976)
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
- Black
- 56.54 cm x 22.4 cm x 35.68 cm - with stand
- 5.1 kg
- VGA , DVI
Mechanical
- Tilt Angle
- -3/+25
- Swivel Angle
- 90
- Rotation Angle
- -1/+95
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- PVC free
- Cables Included
- 1 x VGA cable
- Input Voltage
- AC 120/230 V
- 27 W
- Power Consumption SDR (On mode)
- 27 kWh/1000h
- Power Consumption (Typical)
- 23 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Windows 8.1
- Dimensions & Weight Details
- With stand - width: 56.54 cm - depth: 22.4 cm - height: 35.68 cm - weight: 5.1 kg , Without stand - width: 56.54 cm - depth: 5.66 cm - height: 33.32 cm - weight: 3.4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
