Samsung S24E391HL 23.6" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: BWX8WS00 Mfr#: LS24E391HL/EN
With a beautiful semi-transparent finish, Samsung's Touch of Color technology optimizes your living space and completely sets it apart. The bezels on all four sides are super slim, especially the one running along the bottom. Not only does it deliver a clean and modern look, it naturally draws your eyes to the screen.
Delivers a 178° wide viewing angle horizontally and vertically for an optimal and comfortable viewing experience from any angle. A truly fast 4 ms response time lets you see even the fastest on-screen motion clearly and smoothly with less motion blur, judder, and ghosting.
  • Slim ToC
  • Slim narrow bezel
  • T-shaped stand
    Using touch of color for the T-shape stand completes the ensemble with a refined, minimal finish.
  • Wide viewing angle
  • Eye saver mode
    Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye saver mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free technology
    Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
  • Eco saving plus
    Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (minimum at 25% and maximum at 50%), there is now an auto setting that reduces energy up about 10%, based on the luminescence of the screen's black sections. The screen brightness transitions fluidly while simultaneously saving energy.
  • Enjoy smooth images even during fast moving scenes
  • Upscale your view with better quality and picture
    Magic upscale improves resolution of lower quality images and video so you can enjoy enhanced quality regardless of the original source.
Samsung S24E391HL - SE391 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
21 W
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
High glossy white
54.83 cm x 18.19 cm x 40.9 cm
4.02 kg
Environmental Standards
ENERGY STAR Qualified
IEC 62087 Edition 2
Display Type
Energy Class
Class A
30 kWh
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
High glossy white
54.83 cm x 18.19 cm x 40.9 cm - with stand
4.02 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-2/+15
PVC free
1 x VGA cable
IEC 62087 Edition 2
Power Supply
External
Input Voltage
AC 120/230 V
21 W
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 54.83 cm - depth: 18.19 cm - height: 40.9 cm - weight: 4.02 kg , Without stand - width: 54.83 cm - depth: 6.99 cm - height: 33.33 cm - weight: 3.47 kg
Sustainability Information
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
