Samsung S24D330H 24" 1920x1080 1ms HDMI Monitor
Quicklinx: CCXXWS00 Mfr#: LS24D330HSX/EN
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
Select:
  • 24"
More than 50 in stock
£83.04 ex VAT
£99.64 inc VAT
The Samsung LED Monitor SD300 Series does all the work you need in just the right manner. Functional and with a stylish design, this monitor is all you need.
  • Simple, easy-to-use design
    The 330 series features a slim panel and a stylish cabinet for a sophisticated look.
  • Exceptional picture quality
    Samsung's panel delivers deep blacks with rich, vivid color and sharp detail. The wide viewing angle lets you view your screen comfortably even from off angles, perfect for team huddles and collaborating with colleagues.
  • Optimized for video
    With the touch of a button you can improve your video or gaming experience. Game mode detects changes in scenes, enhances colors and adjusts contrast so you get a crisp, sharp, blur-free picture with no juddering.
Samsung S24D330H - SD300 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
High glossy black
56.9 cm x 19.7 cm x 41.72 cm
3.15 kg
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
High glossy black
56.9 cm x 19.7 cm x 41.72 cm - with stand
3.15 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+20
PVC free
1 x HDMI cable
AC 120/230 V
25 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.72 cm - weight: 3.15 kg , Without stand - width: 56.9 cm - depth: 5.39 cm - height: 34.21 cm - weight: 2.8 kg
10 °C
10 - 80% (non-condensing)
Samsung S24D330H 24 Bundle deal on Samsung S24D330H 24" 1920x1080 1ms HDMI Monitor
£182.21
CCXX StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.91
CCXX StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £110.82
CCXX StarTech.com Articulating Monitor Arm In Stock £103.13
CCXX StarTech.com Dual Monitor Stand In Stock £70.24
CCXX StarTech.com Cubicle Monitor Hanger In Stock £46.01
CCXX StarTech.com Monitor Arm - Heavy Duty In Stock £73.69
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CCXX 042595
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £50.15
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 24in
Response Time: 1ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Samsung
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
