Samsung S24D330H 24" 1920x1080 1ms HDMI Monitor
Quicklinx: CCXXWS00 Mfr#: LS24D330HSX/EN
Select:
  • 24"
The Samsung LED Monitor SD300 Series does all the work you need in just the right manner. Functional and with a stylish design, this monitor is all you need.
  • Simple, easy-to-use design
    The 330 series features a slim panel and a stylish cabinet for a sophisticated look.
  • Exceptional picture quality
    Samsung's panel delivers deep blacks with rich, vivid color and sharp detail. The wide viewing angle lets you view your screen comfortably even from off angles, perfect for team huddles and collaborating with colleagues.
  • Optimized for video
    With the touch of a button you can improve your video or gaming experience. Game mode detects changes in scenes, enhances colors and adjusts contrast so you get a crisp, sharp, blur-free picture with no juddering.
Samsung S24D330H - SD300 Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/362925
Energy Class
Class G
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
High glossy black
56.9 cm x 19.7 cm x 41.72 cm
3.15 kg
Display Type
Energy Class
Class G
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode
High glossy black
56.9 cm x 19.7 cm x 41.72 cm - with stand
3.15 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+20
PVC free
1 x HDMI cable
Input Voltage
AC 120/230 V
23 W
23 kWh/1000h
Power Consumption (Typical)
25 watt
Power Consumption (Off Mode)
0.3 watt
Windows 10
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.72 cm - weight: 3.15 kg , Without stand - width: 56.9 cm - depth: 5.39 cm - height: 34.21 cm - weight: 2.8 kg
10 °C
10 - 80% (non-condensing)
CCXX StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
CCXX StarTech.com Dual Monitor Stand In Stock £82.12
CCXX StarTech.com TV/Monitor Arm - Wallmount In Stock £84.28
CCXX StarTech.com Monitor Arm - Heavy Duty In Stock £95.48
