Your basket is empty
Samsung S24D300HS 24" 1920x1080 2ms VGA HDMI Black Monitor
Quicklinx: 9S5DWS00 Mfr#: LS24D300HS/XU
Experience amazing levels of color, brilliance and picture quality through the very latest in mega dynamic contrast ratio! Samsung SA300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5,000,000:1 contrast ratio, the highest level currently available, the SA300 monitor ensures that blacks are at their absolute darkest and colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colors and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio - and enjoy your multimedia content with the professionalism it deserves.
Samsung 3 Series S24D300H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
High glossy black
56.9 cm x 19.7 cm x 41.72 cm
3.15 kg
Environmental Standards
ENERGY STAR Qualified
RoHS
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale
High glossy black
56.9 cm x 19.7 cm x 41.72 cm - with stand
3.15 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-1/+20
1 x VGA cable
RoHS
Power Supply
External
18 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 19.7 cm - height: 41.72 cm - weight: 3.15 kg , Without stand - width: 56.9 cm - depth: 5.39 cm - height: 34.21 cm - weight: 2.8 kg
ENERGY STAR Certified
9S5D C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9S5D C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
9S5D C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
9S5D C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
9S5D C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
9S5D C2G Pro HDMI to VGA Converter In Stock £46.35
