Product
Brand
Samsung S22E650D 21.5" 1920x1080 4ms VGA HDMI DP PLS LED Monitor
Quicklinx: D7D9WS00 Mfr#: LS22E65UDSG/EN
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: DisplayPort, DVI, VGA (HD-15)
Select:
  • 21.5"
More than 50 in stock
£117.03 ex VAT
£140.43 inc VAT
The Samsung LED Business Monitor SA650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SA650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SA650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SA650 is ready to deliver an efficient and clean work space. The SA650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SA650.
The Samsung LED Business Monitor SA650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce new ways of working. The SA650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SA650.
Samsung SE650 Series S22E650D - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
50.43 cm x 21 cm x 35.44 cm
4.87 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
50.43 cm x 21 cm x 35.44 cm - with stand
4.87 kg
VGA , DVI , DisplayPort
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
1 x DVI cable , 1 x VGA cable
AC 120/230 V
22 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Dimensions & Weight Details
With stand - width: 50.43 cm - depth: 21 cm - height: 35.44 cm - weight: 4.87 kg , Without stand - width: 50.43 cm - depth: 5.54 cm - height: 30.19 cm - weight: 3.27 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Diagonal Size: 22in
Response Time: 4ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 100 - 150
