Samsung S22E450F 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: BKMJWS00 Mfr#: LS22E45UFS/EN
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
Hurry, only 2 left in stock!
£102.66 ex VAT
£123.19 inc VAT
The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. The features of this 19" monitor include a simple and easy to use design, fully adjustable stand, matte bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
  • Environmentally friendly
    With 30% recycled plastic, less than 0.005W off-mode power consumption, Eco features to reduce power consumption when the monitor is in use and fully recyclable packaging, this is the perfect value monitor for the environmentally-conscious business.
  • Impressive picture quality
    The LED-backlit LCD screen delivers sharp, bright and beautiful images. Mega infinity dynamic contrast ratio helps to ensure subtle detail even in the lights and darks, and MagicAngle technology delivers quality color even when viewed off-angle.
  • Slim design that fits any desk
    The sleek, stylish design and low profile stand take up less desk space and contribute to a cleaner-looking office. The built-in cable management feature also adds to a clutter-free work environment.
  • Ergonomic, adjustable stand
    The monitor swivels, tilts, pivots and is height-adjustable. And since it is VESA compatible, installation on a wall or separate mounting arms is easy.
  • Fast, easy connectivity
    VGA and DVI provide flexibility in high-speed connectivity. So whatever devices your employees need to connect today or in the future, this monitor keeps everyone's options open.
Samsung S22E450F - SE450 Series - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
23 W
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
50.43 cm x 21 cm x 32.53 cm
4.57 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
3-year warranty
Display Type
Energy Class
Class B
32 kWh
23 W
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Mega Dynamic Contrast Ratio, Flicker Free technology, Smart Energy Saving technology, Eye Saver Mode, Off Timer Plus, 72% (NTSC 1976) colour gamut
50.43 cm x 21 cm x 32.53 cm - with stand
4.57 kg
VGA , DVI , HDMI , 2 x USB
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
PVC free
1 x VGA cable
AC 120/230 V
Power Consumption Stand by
0.3 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 50.43 cm - depth: 21 cm - height: 32.53 cm - weight: 4.57 kg , Without stand - width: 50.43 cm - depth: 5.54 cm - height: 30.19 cm - weight: 3.07 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Samsung S22E450F 21.5 Bundle deal on Samsung S22E450F 21.5" 1920x1080 5ms VGA DVI HDMI LED Monitor
£201.83
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 100 - 150
