Samsung S22E450DW 22" 1680X1050 5ms VGA DVI DP TN LED Monitor
Quicklinx: D7D4WS00 Mfr#: LS22E45UDWG/EN
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, DVI, VGA (HD-15)
£117.66 ex VAT
£141.19 inc VAT
The SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
  • Environmentally friendly
    With 30% recycled plastic, less than 0.005W off-mode power consumption, Eco features to reduce power consumption when the monitor is in use and fully recyclable packaging, this is the perfect value monitor for the environmentally-conscious business.
  • Impressive picture quality
    The LED-backlit LCD screen delivers sharp, bright and beautiful images. Mega infinity dynamic contrast ratio helps to ensure subtle detail even in the lights and darks, and MagicAngle technology delivers quality color even when viewed off-angle.
  • Slim design that fits any desk
    The sleek, stylish design and low profile stand take up less desk space and contribute to a cleaner-looking office. The built-in cable management feature also adds to a clutter-free work environment.
  • Ergonomic, adjustable stand
    The monitor swivels, tilts, pivots and is height-adjustable. And since it is VESA compatible, installation on a wall or separate mounting arms is easy.
  • Fast, easy connectivity
    VGA and DVI provide flexibility in high-speed connectivity. So whatever devices your employees need to connect today or in the future, this monitor keeps everyone's options open.
Samsung S22E450DW - SE450 Series - LED monitor - 22"
LED-backlit LCD monitor - 22"
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA, DisplayPort
Display Position Adjustments
50.24 cm x 21 cm x 38.75 cm
5.03 kg
Intertek GS
Display Type
Diagonal Size
22"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicRotation, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
50.24 cm x 21 cm x 38.75 cm - with stand
5.03 kg
VGA , DVI , DisplayPort , 2 x USB
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DisplayPort cable
Intertek GS
AC 120/230 V
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 50.24 cm - depth: 21 cm - height: 38.75 cm - weight: 5.03 kg , Without stand - width: 50.24 cm - depth: 5.57 cm - height: 32.98 cm - weight: 3.42 kg
10 °C
10 - 80% (non-condensing)
Samsung S22E450DW 22 Bundle deal on Samsung S22E450DW 22" 1680X1050 5ms VGA DVI DP TN LED Monitor
£217.42
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 100 - 150
