Samsung S22E450BW 22" 1680x1050 5ms VGA DVI LED Monitor
Quicklinx: BKMDWS00 Mfr#: LS22E45KBWV/EN
Diagonal Size: 22in
Max Resolution: 1680 x 1050
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
More than 50 in stock
£95.58 ex VAT
£114.69 inc VAT
The SE450 series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Samsung S22E450BW - SE450 Series - LED monitor - 22"
LED-backlit LCD monitor - 22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
50.24 cm x 21 cm x 35.34 cm
5.03 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
3-year warranty
Display Type
Diagonal Size
22"
Panel Type
TN
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
50.24 cm x 21 cm x 35.34 cm - with stand
5.03 kg
VGA , DVI
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
PVC free
1 x VGA cable , 1 x DVI cable
AC 120/230 V
19 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 50.24 cm - depth: 21 cm - height: 35.34 cm - weight: 5.03 kg , Without stand - width: 50.24 cm - depth: 5.57 cm - height: 32.98 cm - weight: 3.42 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
BKMD StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £112.29
BKMD StarTech.com Articulating Monitor Arm In Stock £103.13
BKMD StarTech.com Dual Monitor Stand In Stock £70.24
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 50 - 100
