The SE450 series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
- Samsung S22E450BW - SE450 Series - LED monitor - 22"
- LED-backlit LCD monitor - 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- 1680 x 1050 at 60 Hz
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Height, pivot (rotation), swivel, tilt
- Black
- 50.24 cm x 21 cm x 35.34 cm
- 5.03 kg
- Environmental Standards
- ENERGY STAR Qualified
- C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
- 3-year warranty
- Display Type
- Diagonal Size
- 22"
- Panel Type
- TN
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.282 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus
- Black
- 50.24 cm x 21 cm x 35.34 cm - with stand
- 5.03 kg
- VGA , DVI
Mechanical
- Tilt Angle
- -3/+25
- Swivel Angle
- 90
- Rotation Angle
- -1/+95
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- PVC free
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Voltage Required
- AC 120/230 V
- 19 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.005 Watt
- OS Required
- Windows 8.1
- Dimensions & Weight Details
- With stand - width: 50.24 cm - depth: 21 cm - height: 35.34 cm - weight: 5.03 kg , Without stand - width: 50.24 cm - depth: 5.57 cm - height: 32.98 cm - weight: 3.42 kg
- ENERGY STAR Certified
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£203.89
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £109.46 |
StarTech.com Articulating Monitor Arm | In Stock | £101.86 |
StarTech.com Dual Monitor Stand | In Stock | £69.36 |
StarTech.com Cubicle Monitor Hanger | In Stock | £45.29 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £50.91 |
