Samsung S22E450B 21.5" 1920x1080 5ms VGA DVI LED Monitor
Quicklinx: BKMCWS00 Mfr#: LS22E45KBSV/EN
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
Select:
£88.54 ex VAT
£106.24 inc VAT
SE450 Series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. The features of this 21.5" monitor include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
  • Environmentally friendly
    With 30% recycled plastic, less than 0.005W off-mode power consumption, Eco features to reduce power consumption when the monitor is in use and fully recyclable packaging, this is the perfect value monitor for the environmentally-conscious business.
  • Impressive picture quality
    The LED-backlit LCD screen delivers sharp, bright and beautiful images. Mega infinity dynamic contrast ratio helps to ensure subtle detail even in the lights and darks, and MagicAngle technology delivers quality color even when viewed off-angle.
  • Slim design that fits any desk
    The sleek, stylish design and low profile stand take up less desk space and contribute to a cleaner-looking office. The built-in cable management feature also adds to a clutter-free work environment.
  • Ergonomic, adjustable stand
    The monitor swivels, tilts, pivots and is height-adjustable. And since it is VESA compatible, installation on a wall or separate mounting arms is easy.
  • Fast, easy connectivity
    VGA and DVI provide flexibility in high-speed connectivity. So whatever devices your employees need to connect today or in the future, this monitor keeps everyone’s options open.
Samsung S22E450B - SE450 Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
50.43 cm x 21 cm x 32.53 cm
4.57 kg
Environmental Standards
ENERGY STAR Qualified
C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
MagicBright, MagicAngle, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, 72% (NTSC 1976) colour gamut
50.43 cm x 21 cm x 32.53 cm - with stand
4.57 kg
VGA , DVI
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Rotation Angle
-1/+95
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
PVC free
1 x VGA cable , 1 x DVI cable
AC 120/230 V
21 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.005 Watt
Windows 8.1
Dimensions & Weight Details
With stand - width: 50.43 cm - depth: 21 cm - height: 32.53 cm - weight: 4.57 kg , Without stand - width: 50.43 cm - depth: 5.54 cm - height: 30.19 cm - weight: 3.07 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 °C
10 - 80% (non-condensing)
Samsung S22E450B 21.5 Bundle deal on Samsung S22E450B 21.5" 1920x1080 5ms VGA DVI LED Monitor
£187.71
BKMC StarTech.com Articulating Monitor Arm In Stock £101.86
BKMC StarTech.com Dual Monitor Stand In Stock £69.36
BKMC StarTech.com Cubicle Monitor Hanger In Stock £45.29
BKMC StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
BKMC StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Samsung
Price Range Ex VAT: 50 - 100
