Define your space with a stylish new design accentuated by slim bezels and soft blue light
- New Slim ToC: With a beautiful new semi-transparent blue finish, Samsung’s innovative Touch of Colour technology optimises your living space and completely sets it apart.
- Slim Narrow Bezel: The bezels on all four sides are super slim, especially the one running along the bottom. Not only does it deliver a clean and modern look, it naturally draws your eyes to the screen.
- T-Shaped Stand: Using Touch of Colour for the T-shape stand completes the ensemble with a refined, minimal finish.
Brilliant picture quality for the optimal viewing experience
- Wide Viewing Angle: Delivers a 178° wide viewing angle horizontally and vertically for an optimal and comfortable viewing experience from any angle.
- FHD: Provides clean and crisp picture quality in 1920 x 1080 resolution.
Easy on the eyes for a more comfortable viewing experience
- Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
- Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy and the environment with this eco-friendly monitor
- Eco Saving Plus: Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (Minimum at 25% and Maximum at 50%), there is now a brand new Auto Setting that reduces energy up about 10%*, based on the luminescence of the screen’s black sections. The screen brightness transitions fluidly while simultaneously saving energy.
- PVC Free: Monitor mechanisms and circuits are constructed without PVC* making for an eco-friendly device, lessening environmental impact. * Based on internal testing * Some cabling contains PVC
Slim ToC
With a beautiful semi-transparent finish, Samsung's Touch of Color technology optimizes your living space and completely sets it apart. -
Slim narrow bezel
The bezels on all four sides are super slim, especially the one running along the bottom. Not only does it deliver a clean and modern look, it naturally draws your eyes to the screen. -
T-shaped stand
Using touch of color for the T-shape stand completes the ensemble with a refined, minimal finish. -
Wide viewing angle
Delivers a 178° wide viewing angle horizontally and vertically for an optimal and comfortable viewing experience from any angle. -
FHD
Provides clean and crisp picture quality in 1920 x 1080 resolution. -
Eye saver mode
Unlike other colors emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye saver mode optimizes your viewing comfort by smartly reducing blue light emissions at the touch of a button. -
Flicker Free technology reduces screen flickering for a more comfortable viewing experience. -
Enjoy smooth images even during fast moving scenes
A truly fast 4 ms response time lets you see even the fastest on-screen motion clearly and smoothly with less motion blur, judder, and ghosting. -
Upscale your view with better quality and picture
Magic upscale improves resolution of lower quality images and video so you can enjoy enhanced quality regardless of the original source.
- Samsung S22E391H - SE391 Series - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class B
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 22 W
- Panel Type
- Plane to Line Switching (PLS)
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Shiny white
- 51.906 cm x 16.746 cm x 39.168 cm
- 3.55 kg
- Environmental Standards
- ENERGY STAR Qualified
- IEC 62087 Edition 2
- Display Type
- Energy Class
- Class B
- 31 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.24825 mm
- Brightness
- 250 cd/m²
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Eco Saving Plus, Eye Saver Mode
- Shiny white
- 51.906 cm x 16.746 cm x 39.168 cm - with stand
- 3.55 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- PVC free
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- Input Voltage
- AC 120/230 V
- 22 W
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 51.906 cm - depth: 16.746 cm - height: 39.168 cm - weight: 3.55 kg , Without stand - width: 51.906 cm - depth: 7.008 cm - height: 32.77 cm - weight: 3.05 kg
Sustainability Information
- ENERGY STAR Certified
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
