Your basket is empty
Samsung S22E391HS 22" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: BWX2WS00 Mfr#: LS22E391HS/EN
Define your space with a stylish new design accentuated by slim bezels and soft blue light
  • New Slim ToC: With a beautiful new semi-transparent blue finish, Samsung’s innovative Touch of Colour technology optimises your living space and completely sets it apart.
  • Slim Narrow Bezel: The bezels on all four sides are super slim, especially the one running along the bottom. Not only does it deliver a clean and modern look, it naturally draws your eyes to the screen.
  • T-Shaped Stand: Using Touch of Colour for the T-shape stand completes the ensemble with a refined, minimal finish.
Brilliant picture quality for the optimal viewing experience
  • Wide Viewing Angle: Delivers a 178° wide viewing angle horizontally and vertically for an optimal and comfortable viewing experience from any angle.
  • FHD: Provides clean and crisp picture quality in 1920 x 1080 resolution.
Easy on the eyes for a more comfortable viewing experience
  • Eye Saver Mode: Unlike other colours emitted from screens, blue light wavelengths have a more stimulating effect on the retina, causing eye fatigue. Eye Saver Mode optimises your viewing comfort by smartly reducing blue light emissions at the touch of a button.
  • Flicker Free: Flicker Free technology reduces screen flickering for a more comfortable viewing experience.
Save energy and the environment with this eco-friendly monitor
  • Eco Saving Plus: Eco-saving technology reduces screen brightness for increased energy efficiency. In addition to the two standard manual settings (Minimum at 25% and Maximum at 50%), there is now a brand new Auto Setting that reduces energy up about 10%*, based on the luminescence of the screen’s black sections. The screen brightness transitions fluidly while simultaneously saving energy.
  • PVC Free: Monitor mechanisms and circuits are constructed without PVC* making for an eco-friendly device, lessening environmental impact. * Based on internal testing * Some cabling contains PVC
Samsung SE391 Series S22E391H - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
22 W
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Shiny white
51.906 cm x 16.746 cm x 39.168 cm
3.55 kg
Environmental Standards
ENERGY STAR Qualified
IEC 62087 Edition 2
Display Type
Energy Class
Class B
31 kWh
22 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Eco Saving Plus, Eye Saver Mode
Shiny white
51.906 cm x 16.746 cm x 39.168 cm - with stand
3.55 kg
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-2/+15
PVC free
1 x VGA cable
IEC 62087 Edition 2
Power Supply
External
AC 120/230 V
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 51.906 cm - depth: 16.746 cm - height: 39.168 cm - weight: 3.55 kg , Without stand - width: 51.906 cm - depth: 7.008 cm - height: 32.77 cm - weight: 3.05 kg
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
