Samsung S22E390H 21.5" 1920 x 1080 4ms VGA HDMI LED Monitor
Quicklinx: BWX0WS00 Mfr#: LS22E390HS/EN
22" FHD monitor Stylish new design SE390 S22E390H
  • Define your space with a stylish new design accentuated by slim bezels and soft blue light
  • Brilliant picture quality for the optimal viewing experience
  • New Slim ToC: With a beautiful new semi-transparent blue finish, Samsung’s innovative Touch of Color technology optimizes your living space and completely sets it apart.
  • T-Shaped Stand: Using Touch of Color for the T-shape stand completes the ensemble with a refined, minimal finish.
Samsung S22E390H - SE390 Series - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
22 W
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
High-gloss black
51.906 cm x 16.746 cm x 39.168 cm
3.55 kg
Environmental Standards
ENERGY STAR Qualified
IEC 62087 Edition 2
Display Type
Energy Class
Class B
31 kWh
Diagonal Size
21.5"
Panel Type
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24825 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Mercury free, Image Size, Eco Saving Plus, Eye Saver Mode
High-gloss black
51.906 cm x 16.746 cm x 39.168 cm - with stand
3.55 kg
VGA , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
PVC free
1 x VGA cable
IEC 62087 Edition 2
Power Supply
External
Input Voltage
AC 120/230 V
22 W
Power Consumption (Typical)
21 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS, Windows 8.1
Dimensions & Weight Details
With stand - width: 51.906 cm - depth: 16.746 cm - height: 39.168 cm - weight: 3.55 kg , Without stand - width: 51.906 cm - depth: 7.008 cm - height: 32.77 cm - weight: 3.05 kg
Sustainability Information
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
